Old 06-15-2019, 07:44 AM
KRviator's Avatar
KRviator KRviator is offline
Default [Video] - Short field landings in the -9A
When I built the -9A, I enabled the datalogging feature on the SkyView as well as installing a Navman MiVue 530 Dash-camera on the roll bar behind the Coey's seat. As most of my flights are solo, the view of the back of a head is fairly infrequent and it provides a video and data log of all my flights and actions in the event I spear in.
I downloaded the card the other day to grab some footage of my recent landings to measure the numbers and you can see the results for yourself. The -9A, admittedly one of the lighter ones out there, can consistently pull off ground rolls under 600' with moderate braking on a slightly uphill runway and is likely capable of sub-400' ground rolls for a maximum performance landing if need be. You can also have fun showing off to Diamond pilots at the holding point by crossing the threshold on a 3000' runway at 250' AGL and still make the turnoff at the far end.
The runway at Somersby is only 600m / 2000' long, 850'AMSL and on top of a plateau, slopes down 2* to the north and is surrounded by trees, so most FW landings tend to use Runway 17 and takeoff on 35, irrespective of the wind.
For those considering a -9A, enjoy!
https://youtu.be/VBPCMDG-YqI
Once you have tasted flight you will forever walk the earth with your eyes turned skywards, for there you have been and there you will long to return - Leonardo DaVinci
My Flickr gallery: http://www.flickr.com/photos/35521362@N06/
RV-9A - Finished on 10th February 2016 after 4 years, 9 months and 19 days! The 1020th RV-9 flying.
First flight 26th March 2016. Essential specs 145KTAS @ 2400RPM, 8000', 24.2LPH, Initial RoC 1800FPM.
Old 06-15-2019, 10:45 AM
PilotjohnS PilotjohnS is offline
Default Great video
Great video thanks. Cant wait to get mine up and going!
John S
WARNING! Information presented in this post is my opinion. All users of info have sole responsibility for determining accuracy or suitability for their use.
Dues paid 2021, worth every penny
RV9A- Status:
95% done, 10% left to go
Electrical/Panel done
Firewall Forward 75%done
Fiberglass 0%, thought i was building in metal?
www.pilotjohnsrv9.blogspot.com
Old 06-16-2019, 11:43 PM
petehowell's Avatar
Default Loved It!
Man that is great! I could only land that short with a hefty headwind. What is your engine/prop setup? Approach speed? Full flaps? Do you use AOA?
Sorry for all of the questions! Well done!
Pete
Amateur Plane - RV-9A N789PH - 2450+ Hrs
Amateur Radio - KD0CVN
Doggies Delivered - 25+
St. Paul, MN
Old 06-16-2019, 11:52 PM
KRviator's Avatar
No problems with the questions!
I have a de-rated (7.5:1 CR/165HP) OX-340S turning a Sensenich GA prop. Into Somersby I usually fly 55-60KIAS though typically fly AoA rather than a set speed, eyes out and listening to the SkyView beeps I usually only glance at the ASI every 10 seconds or so if I had to guesstimate. All approaches are made with full flap, yep.
My -9A has a 600Kg / 1320Lb regulatory MTOW limit at the moment, so I do benefit somewhat there vs a heavier RV.
Old 06-17-2019, 06:56 AM
petehowell's Avatar
Default Nice!
Thanks for the info. Light is good!
I Just measured the first turnoff of Runway 09 at KANE where I am based, and it looks to be about 700 ft. I can make it pretty consistently, but only with a nice breeze down the center line. I'm 1750 max with a CS Hartzell.
I like your camera setup, and I too use the beeping Dynon AOA when landing short.
Once again well done, you have a great plane there!
Pete
St. Paul, MN
Old 06-17-2019, 10:36 AM
luddite42 luddite42 is offline
A Pitts can achieve a 600' ground roll. Don't touch down so flat.
Old 06-17-2019, 03:18 PM
simpkinsona simpkinsona is offline
Default Still upright
I hate to be ?that guy? by criticizing another pilot. The landings you are doing in this video show you lowering the nose wheel to the ground immediately after touchdown. This is a very dangerous technique and the cause of many inverted RV A models. Being on an unpaved surface with this technique is even more dangerous. Sorry, but I just don?t want to see you have a problem.
-Andy
Andy Simpkinson
RV-9a Subaru engine.
Old 06-17-2019, 03:59 PM
Low Pass's Avatar
Low Pass Low Pass is offline
That to me is the most appealing thing about the -9. Slow landings. Thanks for sharing!
Bryan
Houston
Old 06-17-2019, 04:26 PM
Finley Atherton Finley Atherton is offline
-Andy
I agree the nose wheel should be kept off the ground as long as possible but a short field landing requires at least moderate braking which will bring the nose down prematurely even with the stick held back. I believe the nose wheel/strut can take this with a good margin of safety if the surface is not soft. An aft c of g and immediately raising the flaps when the mains touch helps.
Fin. 9A
Old 06-17-2019, 05:48 PM
KRviator's Avatar
I hate to be “that guy” by criticizing another pilot. The landings you are doing in this video show you lowering the nose wheel to the ground immediately after touchdown. This is a very dangerous technique and the cause of many inverted RV A models. Being on an unpaved surface with this technique is even more dangerous. Sorry, but I just don’t want to see you have a problem.
-Andy
I do appreciate the concern Andy, and you are correct, I do tend to derotate early in these videos, but that is predominately to get the nose down relatively under control, versus having it slammed down during braking. On normal landings or during T&G's I hold the nose off as long as I can.
You can kinda see it very late in the ground roll of the first landing, there is an area of runway abeam the hangars where it drops away slightly and if you hit that at any decent speed you can either A) get bounced into the air well below flying speed, or B) come down very hard on the nose gear, and as a result I tend to want to get all three wheels down and be under brakes as early as I can to stop before it. We had an unfortunate fatal accident in an RV-6A at Somersby last year where the pilot landed the other way and went off the end, and I would rather risk a nose gear failure than try to soften the landing.
