Old 06-10-2019, 11:26 AM
WA85's Avatar
WA85 WA85 is offline
Default Dynon 15.4.7 firmware PIREP
Updated my Dynon Skyview Classic to 15.4.7 firmware this weekend - a few observations
1. Loading 15.4.7 firmware took about 5 minutes to load, but my GPS 2020 showed it needed an additional update to....that took about 15 minutes longer. Be patient.
2. My EGT inidcations seem to be hyper sensentive to any changes in mixture or turning on the smoke system. Before 15.4.7 firmware, turning on my smoke system did nothing to my EGT, now it shows a near instant cooling affect / decrease by about 600 deg on the two cyclinders I have injectors. Using the LOP function, the EGTs seem to jump around quite a bit at Peak / LOP than before the 15.4.7 firmware. Not sure if the sensor updates have anything to do with this or it just my system.
3. While flying through the traffic rich DFW class B, traffic now seems to be less prone to ghosting / drop out, as compared to my Garmin ADSB in. This might be due to my GPS 2020 needing an update.
4. My Skyview WiFi now links up great with my foreflight for ADSB in traffic and weather....got a great exercise with it yesterday. It used to be problematic.
5. The 15.4.7 firmware added 0.0000865 kts to my cruise speed.
Old 06-10-2019, 11:33 AM
Gash's Avatar
Gash Gash is offline
I got an extra 5 knots TAS! You must have done something wrong.
Karl, Goodyear, Arizona (KGYR) ATP, CFII
RV-14A
Yak 50
=VAF= donor 2021
Old 06-10-2019, 11:36 AM
scrollF4's Avatar
scrollF4 scrollF4 is online now
Moderator, Asst. Line Boy
Regarding your EGT observations, I corroborate your observations with my own identical readings (including smoke). Must be a sensor sample rate change, although the Dynon tech folks told me nothing changed with the EMS functions.
Scroll
Catch her on YouTube's "Because I Fly!" channel
Exemption waived.
Proud and grateful 2021 -=VAF=- Contributor
PS: I am not an influencer. I have no influence. Just ask my kids.
Old 06-10-2019, 12:01 PM
RViter RViter is offline
Default one more change?
A change noted, not listed
#6 - (FF) Now see Ground Aircraft movement (TIS-B) ... already had the airborne targets but now see brown/tan ground targets.
Had a Beta which showed the TIS/FIS on ForeFlight but the ground aircraft my home field (FFZ) weren't shown. With a very active flight training presence that is useful. We have a very close 'ground station'. My installation includes Dynon ADSB-in (dual freq -472) and -out (261 Xpndr).
Only had a quick taxi test after installing v15.4.7.xx so can't comment on EGT sensors.
gary
RV-6A QB Tip-Up, 1st Flight 3/18/17
O-360-J2A (modified & F/I), Sensenich FP (cruise)
VP-X Sport, Dynon SkyView, VFR day
(FFZ) Mesa, AZ - N234GB -
www.mykitlog.com/garyc
Old 06-10-2019, 12:10 PM
rvator51's Avatar
rvator51 rvator51 is offline
Default VNE
I also saw you can show VNE now as both TAS and IAS.
Regards,
Thomas Velvick
Goodyear, AZ (KGYR)
2020 Donation sent.
N53KT RV-6a finished 2018, Flying
N7053L RV-4 Wife's RV
N56KT RV-4 Finishing
Old 06-10-2019, 02:17 PM
RV7A Flyer's Avatar
Originally Posted by rvator51 View Post
I also saw you can show VNE now as either TAS or IAS.
I thought that's been in there for quite a while? I have had mine set up to show the redline (well, red "region" on a tape) as a function of IAS for a long time.
2019 Dues paid!
Old 06-10-2019, 05:47 PM
Default minor detail ...
"Added: SkyView can now express Vne as TAS & IAS."
It's "and" not "or" ... the EFIS/PFD is configured to display BOTH Vne values. Some setup required to assign the values.
This is covered in the Pilot's User Guide, Page 4-4, and Figure 15, which displays both formats.
gary
Last edited by RViter : 06-10-2019 at 06:29 PM. Reason: read the manual, new knowledge
Old 06-12-2019, 01:46 PM
RickSolana RickSolana is offline
Default Dynon 15.4.7 effect on final approach
Dynon 15.4.7 has changed the behavior on my final approach course when coupled to the Dynon autopilot. Now I have greater need for power significant power changes to maintain airspeed and end up with a 3/4 scale deviation on glide slope as I approach the DA. Anyone else seeing any effects?
Old 06-12-2019, 03:34 PM
AAflyer's Avatar
AAflyer AAflyer is offline
Default WiFi difference
My Dynon SkyView used to connect to my iPad's Foreflight almost immediately...now, with this update, it took a while for the WiFi icon to appear...so long that I was scrolling and surfing for it somewhere else...but after a minute or so, the "upload to panel" icon showed up.
I hope this was a one-time event.
Bruce Windom
QB RV-8 N148BW
First Flight: Oct '16
AeroSport Power IO-360 180hp w/dual P-Mags
Catto 3-blade, with black carbon spinner.
10" Dynon SkyviewTouch. That's ALL.
Old 06-15-2019, 03:31 AM
RV10inOz's Avatar
RV10inOz RV10inOz is offline
Update completed today (HDX800's and 1100) and the following observations in response to previous posts;
1. EGT values were not any different to the last 1600 hours, so not sure what others are doing. But look closer to your installation.
2. No GPS differences but I do have a 250 unit and a new one not affected by the rollover. I saw nothing new in the ADSB-In but we upside down folk do not have the TIS-B you northerners get
3. Rick's autopilot in VNAV has NOTHING to do with the update. I have been working with him to solve an anomaly, and we found a mechanical issue which he is correcting. He will no doubt discover good results next week.
As for AP performance, all good.
My TAS did go from 164 to 164.......
So far no undocumented design features found. Will do some Skyview Classics tomorrow.
______________________________
David Brown
DYNON Authorised Dealer and Installer
The two best investments you can make, by any financial test, an EMS and APS!
