Old 05-29-2019, 11:44 PM
mbauer mbauer is offline
Default Kenai, Alaska to Yakutat, Alaska
2019 Vacation
Took off from Kenai (PAEN) while a TFR was in effect for Anchorage. Worked most of the day and manager let me leave early at 2pm. Climbed out to 13,500 on my way to Yakutat (PAYA). Cloud cover over the Kenai Mountains as I traveled East towards Prince William Sound [PWS].
The clouds began to disappear as I got closer to the Sound. Just as I cleared the clouds, on the radio (monitoring 121.5) heard an order for the plane taking off from Goose Bay to land immediately due to the TRF. There was no response from the aircraft.
Beautiful sunny weather over PWS allowed easy viewing of the surrounding mountains and ships/boats traveling the Sound.
Cordova (PACV) was in the clear. Took a few photos of the Mudhole Smith Airfield.
Called Anchorage radio and gave a pilot report/position report. Weather was so good failed to ask for an update for Yakutat weather. Sure wished I had done that!
In the distance could see a cloud layer that was below my flight level. Before my takeoff from Kenai, talking with Kenai FSS on telephone they gave a Yakutat report of 3500 scattered with 6500 BKN, and OVC at 9,000.
Best regards
Mike Bauer
Mike Bauer
N999SN 1998 Syd Nelson RV-6 (purchased 2017)
UTC -09:00 Alaska
Old 05-29-2019, 11:49 PM
Default Cont
As I got closer to the cloud layer began my descent to get under the clouds. Did this because of Yakutat reporting a ceiling well below my 13,500 cruising altitude. At 5500MSL well below the base of clouds I continued my flight. Flew into some rain soon after.
As I crossed over Cape Yakataga visibility reduced as the rain was really intense. VFR minimum of 1000ft /3-miles was met. Noticed that the rain ended just off shore and the clouds were much higher. Deviated from my path to get out of the rain. Was able to climb back up to 3500 MSL.
Took some photos of the cloud layers along this route, showing the clouds and the mountains peeking through the different layers as I traveled along. Getting near ICY BAY the clouds began to thin. Decided to climb up to 7500 MSL to fly over Icy Bay into Yakutat. [I like altitude when crossing water in Alaska]. Yakutat was Clear! If I had asked for a weather update, could have stayed up top and would not have been in the rain!
PAEN to PAYA 425.7 SM in 3.0 hours.
Next PAYA to PAPG
Mike
Mike Bauer
UTC -09:00 Alaska
Old 05-30-2019, 06:49 AM
Waiting for you Mike. I hope weather will cooperate and you get to our woods. An escort over NYC and a royal treatment after that is guaranteed. Please keep us updated on your trip progress.
Old 05-30-2019, 04:54 PM
Captain_John's Avatar
Mike,
I like the sneak peek of the new design on the wing!
Looking forward to seeing the entire plane (and you) soon!
Russki, don't just escort him up the Hudson. Keep it going and chauffeur him here!
Enjoy the trip!
CJ
RV-7 Flying - 1,400 Hours
Old 05-30-2019, 11:15 PM
Sky Goddess's Avatar
Sky Goddess Sky Goddess is offline
Vlad---let me know when you guys get close to New England---I want to join you---lunch at 7B3 (Hampton Airfield)---RV-8 Sky Goddess and John Fleurent
you can NOT TEACH experience-----you must acquire it--- RV-8 (first flight 1998)
Old 05-31-2019, 09:41 AM
Default PAYA to PAPG
Quick refuel at Yakutat; 21.2 gal.
For this flight I made a aluminum aux tank that sits in the passenger seat. The tank fits between the angle aluminum that supports the cushions. By tilting the seat back as far as possible it creates an angle that the outflow line now is at the lowest point. In other words the angle creates a "sump" like area. From testing I know that the tank will feed 20.5 gallons of the 23.58 gallon capacity. Strategically placed aluminum pipe cut in half allows a smooth surface to use the seat belt and shoulder harness to secure the tank in place.
The aux tank has an outlet valve that is left in the OPEN position, relying on Van's three-way fuel valve selector to feed fuel directly into the fuel system. It gravity feeds fine, allowing the electric pump to be turned off.
Topped off both main tanks and the aux fuel tank before leaving for Ketchikan (PAKT).
Once in the air called Sitka radio for updated for Ketchikan and Petersburg (PAPG). Weather was clear in both locations. As I neared Mt Fairweather and Mt Crillion began to realize it was showing signs of getting dark earlier than it does in Kenai. Called FSS radio again and asked for Civil Twilight time for both locations.
Leaving Yakutat:
Mt Fairweather at 12'oclock:
Side view of mountains leading to Mt Fairweather:
Mt Fairweather and Mt Crillion closer views:
Next: more photos to show Alaska Panhandle Islands of the South East.
Mike
Mike Bauer
UTC -09:00 Alaska
Old 05-31-2019, 04:41 PM
Maverick 4003 Maverick 4003 is offline
Default Kenai to Yakutat
Thx for photos, as my cousin is the Principal in Yakutak. Copies of trip @ this time will be sent to him.
Old 06-02-2019, 01:03 AM
Default PAYA to PAPG Cont.
Mt Fairweather and Mt Crillion and the horizon are amazing to see first hand, was not able to take just one photo. In other words, here are a few more of them from different angles:
Ok, enough of the mountains; next post will show the islands of Sotheast Alaska pan handle.
Mike
Mike Bauer
UTC -09:00 Alaska
Old 06-02-2019, 01:20 AM
Default PAYA to PAPG cont.
Leaving the mountains behind, Cape Spencer position report and PIREP to Juneau radio. Over water again. Lots of islands to see now:
Part of the "Inside Passage" in the distance.
Sun at lower angle, notice faded look of wing:
Notice the passenger that is riding along on this flight?
12'oclock Mitkof Island where Petersburg is located:
My RV does not have landing/taxi lights and is a VFR only bird.
It would be dark by the time I could make Ketchikan, so decided on Petersburg for my next stop and overnight stay. The sun was almost down when I landed. Using the last of May 24th's sunlight I tied the RV to the ground.
A short .9 of a mile walk had me downtown Petersburg looking for a hotel. After talking with a young lady that was running her dog on the pathway, found out I was near both of Petersburg's hotels.
Following her directions: a right turn where the path T'd into a right and left choice, the Scandia hotel was the first I reached, using my home business license for reference soon had me with a room paying a corporate discount rate of $110 total for a night stay.
Story continues with photos of Petersburg, AK next.
Mike
Mike Bauer
UTC -09:00 Alaska
Old 06-02-2019, 01:48 AM
Default PAPG Petersburg, Alaska
Petersburg is a very quiet fishing community! Bed was comfortable and room was nice with a third story view of downtown and the docks. Set alarm for 0430 planning to leave after breakfast.
After showering the sleep away, immediately cranked up laptop and began looking at weather. Petersburg was clear, however winds were not looking good for a tailwind along my intended path to Bonners Ferry, Idaho (65S) Boundary County. Bonners Ferry was reporting bare VFR minimums with rain. Ok, time to look at alternate KGNG (Gooding, Idaho). Both have cheaper fuel than most places. Weather in Gooding looked better, so that became primary target.
Thinking I was making a quick call to FSS to file a domestic flight plan and get a good weather briefing, changed my plans for the day.
Juneau FSS, Justin who had talked with me the night before on my route from PAYA to PAPG, advised not to fly my route due to icing conditions over British Columbia, Canada.
To verify what he was seeing, he gave me the telephone number for the Kamloops, BC FSS. Called the number and found out that the inland portion of my flight had moderate icing starting at 5500 ft through 23,000 MSL in clouds with rain and mountain obscuration, moderate turbulence as well. Asked for the coastal weather and it was pretty much the same.
The outlook for the next day was clear skies along the coast but the inland portion near the border was forecasting lots of clouds and convection activity.
Decided to stay another night in Petersburg.
Took a short nap until 8am, got up, went for a breakfast sandwich at a local eatery. Afterwards went to my room, grabbed my camera for a walking tour of Petersburg docks. Met and talked with many friendly locals. Saturday the 25th was a pleasant time spent exploring a beautiful sunny day! Around 5pm bought a beer in a local bar called the Harbor Bar (yep fisherman style dive bar) meeting more locals and having a great time talking fishing or lack of; no fish being caught.
On the way back to my room, decided to stop in for a bite to eat at the Mexican food trailer near the hotel.
One of the best bean /cheese burrito I've ever had!
Around 8pm decided to look at the next day's weather before lights out, due to an early 4am wakeup. No, surprises here: still looking like tomorrow would be a great day for flying!
First thing after waking up was to call Kamloops FSS for the weather along my route to Bonners Ferry. Not good: inland lots of convection near the border with Washington and Idaho. The coast report was clear the whole way to Seattle.
Having flown the reverse route back in 2017, decided to fly it again going South this time. Planned to stop at Arlington (KAWO) for fuel. Once knowing the route, called Juneau FSS and asked for Alaska weather along the route, came back CAVU. Filed a domestic flight plan from PAPG to KAWO. Canada airspace is controlled above 13,500 MSL, so planned on 11,500 MSL for southern journey.
After showering, headed back to small restaurant for breakfast of biscuits and gravy, drank some coffee and headed towards the local hardware store that would open at 7am/ but actually opened at 8am due to Memorial Weekend hour change. Bought some better tiedown rope (blue steel) and a couple of stainless steel bowls.
Checked out of the hotel at 0815, received a ride from the hotel's airport shuttle van, back to the RV. A thorough pre-flight found it ready to go.
The afternoon before, topped off the main tanks at Temsco Helicopter FBO/Charter operations. Aux tank was still full from my Yakutat fuel visit.
Takeoff was at 0906. Flew over the bay taking a few photos of Petersburg as I turned to the South East for my heading to Comox, BC.
Ok, in the air again and heading down South.
Continues with photos and story traversing the British Columbia Coastal Mountains next.
Mike
Mike Bauer
UTC -09:00 Alaska
