Old 05-22-2019, 04:36 AM
YvesCH YvesCH is offline
Default Wingtip Installation with Magnetometer in Tip
Hi everyone,
I am about to install my wingtips but I am not yet sure how to attach them to the wings as I have a GMU-11 magnetometer mounted. The manual requires quite a lot of distance to magnetic materials in close proximity. Now I am afraid about the fastener..
If I would go the piano-hinge route there would be the pin which would be magnetic. With the screws there are the nutplates..
Hod did you guys mount your wingtips ?
Yves - Basel, Switzerland
RV-8 #83458 HB-YUA
Donation 2020 done
Old 05-22-2019, 04:44 AM
noelf noelf is offline
The piano hinge pin is stainless material. I have installed a GMU 11 in a Cessna wing, outboard rib, and the wing tip was attached with SS screws and Tinnerman fasteners. No issues.
Noel
RV-6A N6NF
tip-up
flying
Old 05-22-2019, 05:35 AM
F1 Rocket F1 Rocket is offline
FYI, I had the magnetometer mounted in that same location in my Rocket and it turned out to be a bad location. The leading edge weight in the Aileron was magnetic and would cause a 2 deg swing as the Aileron moved up and down.
Danny
F1 Rocket #25
N14ZM "Dreamer"
Melboring, FL
Old 05-22-2019, 06:13 AM
Electrogunner Electrogunner is offline
Default Wingtip
I just recently moved my GMU 44 to the wingtip because of interference in the tailcone. I have the tips fastened using hinges and the pins are slightly magnetic, but I didn't have any calibration issues with it.
RV10 N620RV BUILT, FLEW, SOLD
RV10 N821BS coming soon
Old 05-22-2019, 06:23 AM
Ok thanks, I was not sure what would be worse, the lights or the aileron counterweight. I used all shielded and drilled wires but still mounted the Magnetometer in approx. the middle between the lights and counterweight..
RV-8 #83458 HB-YUA
Donation 2020 done
Old 05-22-2019, 06:24 AM
Thanks, the screws and tinnerman washers are SS but the nutplates are the ones which concerns me. Did the Cessna have magnetig aileron counterweights?
RV-8 #83458 HB-YUA
Donation 2020 done
Old 05-22-2019, 07:55 AM
Dan Langhout's Avatar
Dan Langhout Dan Langhout is offline
Default GMU-11 Mount
Just finished a GMU-11 mount in the left wing of my RV-7. Mounted to the rib straddling the end of the spar. Wingtip is held on by 4-40 stainless screws into non-stainless nutplates on the wingtip. The G5 interference test showed the aileron counterweight and the landing/taxi light wires were the largest disruptors - but both were well within limts (<25%). The GMU-11 calibrated and worked just fine.
Dan Langhout
2021 =VAF= Dues PAID . . . . .
RV-7 N528DP slow build
First Flight July 26th, 2014
837 hours and counting . . . .
28 Pilots N Paws Flights
Now based at Moontown (3M5)
Old 05-22-2019, 09:15 AM
Bavafa Bavafa is offline
I have my GMU 11 in exact same place in a RV14 and have zero issue. The mag calibration testing went without any issues and so far have not has any issues with heading or otherwise.
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - SOLD
N258SM RV14A - IO390EXP119 - in progress
Dues paid
