Go Back   VAF Forums > Model Specific > RV-6/6A
Old 05-16-2019, 12:35 PM
Alchemist Alchemist is offline
Default RV6-A Nose gear inspection
Hello,
A slight rotation was noticed when checking the break out force on my nose wheel, is this normal ? All SB's have been addressed regarding
the nose gear/wheel and it has no noticeable flaws while flying or landing.
https://www.youtube.com/watch?v=NjQ8wUIXw4U
Thanks for the help,
Justin
Old 05-16-2019, 01:20 PM
Bavafa Bavafa is offline
Honestly, I think that is a bit more than a slight. It will only get worse if left unchecked.
Many, including myself either replace the bolt on top with a close tolerance or even better go to a tapered bolt. You may also check to see if there is movement in the socket or just the bolt.
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - SOLD
N258SM RV14A - IO390EXP119 - in progress
Dues paid
Old 05-16-2019, 01:32 PM
As noted above, that needs to be addressed ASAP or it will get worse. With that much play, you will probably need the ream oversize or go with a taper bolt. The taper bolt is the better choice, but access is more of a problem.
Colin P.
RV-6A #20603
Complete 5/10/19
PP SEL / A&P
Old 05-16-2019, 05:48 PM
AlexPeterson's Avatar
Start with the close tolerance bolt, it might fix the problem. They are a few thou larger in diameter than the standard ones. Do not try to simply clamp the bolt tight enough to keep the motion from happening - you will likely grossly over-torque the bolt.
Alex Peterson
RV6A N66AP 1750+ hours
KADC, Wadena, MN
Old 05-16-2019, 06:05 PM
blaplante blaplante is offline
Default ground it now
ground it now. all you need is 1) continue to beat on the bolt, 2) get some nose wheel shimmy, and you'll eventually 3) shear off the bolt. Which will lead to a bad day.
I put in a close tolerance bolt, but mine wasn't this bad. The correct reamer to fit the close tolerance bolt was absurdly expensive so I think I found a reamer on eBay. Probably won't last 100 holes, but I only needed one!
I agree the taper pin is the way to go but I don't know how you'd get the taper cut without pulling the engine. Sorry!
RV6A in phase 2 as of April 2016
Donation made Oct 2021
Old 05-16-2019, 06:40 PM
pa38112 pa38112 is offline
+1. This is a serious issue that can be a 30 minute fix. Take care of it now.
http://aprs.fi/N153MC
2004 RV6A Flying
2002 RV6A Flying
1978 PA38-112
Old 05-16-2019, 06:51 PM
greghughespdx's Avatar
The aircraft is not airworthy. Time to fix. Address it now and it should be fairly simple.
Greg Hughes - Van's Aircraft
Building RV-8A since Sept 2014
Aurora, OR (EAA Chapter 105)
Old 05-16-2019, 08:12 PM
Steve Melton's Avatar
how about just a fresh bolt and check the play.
Steve Melton
Cincinnati, OH
RV-9A, Tip-up, Superior O-320, roller lifters, 160HP, WW 200RV, dual impulse slick mags, oil pressure = 65 psi, EGT = 1300F, flight hours = 900+ for all
I was born an airplane nut. I have no explanation for it.
www.rvplasticparts.com
Old 05-17-2019, 06:46 AM
RONSIM's Avatar
RONSIM RONSIM is offline
Default Nose wheel stop flange in wrong position - THIS
could have caused your problem if in the past it had been installed wrong (probably was) --- I have seen this, just recently, during a condition inspection --- check service bulletin 14-12-22 - so easy to get it wrong, because "it looks right!"
Ron
RV-10 Co-built, maintained, flown (sold)
RV-8A Maintained and flown (Sold)
RV-6A (Sold) Bought and Flying (N177RV), upgrades $$$
IO360, 180HP/CS, AFS 5600T, D10A, G650, G430, G327, ADS-B, VIZ385 AP
Very Happy Contributor
Comm, SMEL, CFII, A&P
Based at KCLW (Clearwater, FL)
Old 05-17-2019, 07:17 AM
bhester's Avatar
bhester bhester is offline
Default Correctly installed
The flange in the video is correctly installed. It could have have been wrong sometime earlier.
Bobby Hester - Builder/Pilot/A&P
Surfing the web from Hopkinsville, KY
N857BH RV7A XP-O360 - Garmin G3X ADS-B IN/OUT 2020 Compliant
Web site: http://www.newtech.com/bobbyhester/RVSite.htm
Dec. 2020 VAF donator - alot better than any magazine subscription
