…… It seems I need to do a little bit of explaining and some clarification as well to you Otis. I performed this service on your wheels myself and remember it due to the disc change. We typically accomplish the bearing upgrade machining with the wheels assembled, prior to disassembly. When we are changing tires and tubes we disassemble and clean all parts in our Jet-Kleen before reassembly. You didn't order tires, and didn't send any in with your request so we just did the bearing change, installed your brake discs, and rebalanced the assemblys. We don't blast the wheels unless we see corrosion, as this removes the plating that prevents magnesium from corroding. I would have performed this service for you no charge if you had told me in advance you wanted it. When balancing we mark the spot where the imbalance is, and wipe this area with brake clean. Then we wipe it with an activator that is necessary to make the bonding agent work. Had this not have been done the weights would not have adhered at all. I am as you are, very disappointed that you were unhappy with our service or work. I wish you had given me a call, and expressed your feelings as soon as you received your wheels, so I could have addressed this immediately. I take a lot of pride in the fact that we don't have any unhappy customers (???). So, that being said, please tell me what we can do to remedy this situation, and get you back on the happy side. I do apologize for any misconceptions and or inconveniences we have caused you, and we will make it right. Thanks, Allan..
