Old 05-08-2019, 01:01 PM
tomjj tomjj is offline
Default RV-10 elevator trim bracket dimensions
Hey gang,
I bought some aftermarket trim cable attachment brackets to replace the stock WD-415s that came with the kit. Like a bonehead, I pitched the OE brackets before realizing that the base dimensions are different. Now, I don't know the dimensions needed to calculate their position on the E-616 cover plates, since the plans on Page 9-7, step 4 only show the distance from the opening to the furthest edge of the bracket!
Would anyone happen to know the dimensions of the WD-415 bracket base (OR their distance from the opening to the nearest bracket edge)?
Worst case, I could spend a few extra bucks on my "next" shipment of "replacement" parts to get another bracket, but was hoping someone would have easy access to the answer (and help me save a few $$ on something I would discard again anyway)...
Thanks!
Tom
Old 05-08-2019, 02:04 PM
jacoby jacoby is offline
They're 1"x1". The angled nut is welded flush with one edge.
Old 05-08-2019, 02:25 PM
bwestfall bwestfall is offline
I second that 1"x1". This one still needs to be replaced w/the nut welded on both sides (not flying).
Ben Westfall
RV-10 104EE flying
Coeur d'Alene, ID
Old 05-08-2019, 05:44 PM
Thanks guys, I really appreciate the super-speedy responses!
Tom
