Old 04-17-2019, 07:19 PM
Girraf Girraf is offline
Default Do I REALLY need a solid rivet here?
The aft most rivets (top and bottom) on the tip ribs of the elevators....
I'd so much rather put an MK-319-BS in those holes and move on than try all sorts of mediocre attempts to set a solid rivet here. I even made a special set of cut down vicegrips into a duck bill type squeezer but in some 15 practice attempts on scrap, I manage to set 1 good rivet tail. And the notion of bucking with a chisel or prybar, I don't know how some of you found success with that.
Vintage Cherokee 160
RV-7:
Empennage complete
SB Wings to QB stage
Fuselage in progress
Old 04-17-2019, 07:22 PM
wirejock's Avatar
wirejock wirejock is offline
Default MK rivet
Yes. Why tempt fate? Plenty of other opportunities to force the issue and dork it up.
I live in a Holiday Inn so I don't make mistakes.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Donated 12/01/2021, plus a little extra.
RV-7A #73391, N511RV reserved (3,000+ hours)
Empennage, wings, fuse, finishing kit done. Working FWF
Disclaimer
Old 04-17-2019, 07:52 PM
Kitbuilt Kitbuilt is offline
Default Another Specialty Tool
When I got to this point a past builder told me he used a hatchet as a buck bar for these and it worked out pretty well for me. I would suggest using painters tape on the hatchet sharpened edge to protect from scratches.
Old 04-17-2019, 08:03 PM
Mel's Avatar
Mel Mel is online now
It is perfectly acceptable to use MK-319-BS rivets here.
Mel Asberry, DAR since the last century. Over 1,000 certifications accomplished. Discount for Veterans, Law Enforcement, Fire Fighters.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
