Old 04-15-2019, 11:23 AM
g3xpert's Avatar
g3xpert g3xpert is offline
Post Garmin G3X (GDU 370/375) Pending Software Release
We wanted to give G3X owners a heads up that there is a subset of GDU 370/375 displays which are affected by the GPS week rollover event which occurred on April 6.
Any affected G3X system is still fine to use and the GPS data including navigation and displayed time is not affected, but in the few places where the date is exposed, like in the flight data log, the time will be correct, but the date will be incorrect.
If you want to see if your system is affected, select Menu, Menu, System Setup, Date & Time and you can see the system date and time.
We have implemented a software fix and are testing this fix before doing a maintenance release soon.
We apologize for any inconvenience this may cause for those affected.
There are no known issues with G3X Touch systems.
Steve
04/25/2019 Update: V11.80 software released
Garmin G3X Support
g3xpert@garmin.com
1-866-854-8433 - 7 to 7 Central Time M to F
Please email us for support instead of using Private Messaging due to the limitations of the latter.
Last edited by g3xpert : 04-25-2019 at 05:50 PM. Reason: Added update regarding released software.
Old 04-16-2019, 06:08 PM
kevinsrv7.com's Avatar
kevinsrv7.com kevinsrv7.com is offline
Steve
Thanks Steve for the heads up. I'm standing by.
Kevin
