Old 04-09-2019, 01:55 PM
FNG FNG is offline
Question Brakes weak
I have an RV-9A with Cleveland brakes. Both linings and rotors were new 25 hours ago when I purchased the aircraft.
The pedals are firm (no air in lines) but the brakes are ineffective. Hardly can hold aircraft at full power, and don?t seem capable of locking the wheel on landing (this may be a good thing).
I thought they would ?break-in? , but not there yet.
Any suggestions? Is this common on RVS? Are the linings maybe glazed?
Tom
Dues paid
Old 04-09-2019, 02:05 PM
Aggie78 Aggie78 is offline
Was this procedure done after the install?
https://www.aircraftspruce.com/catal...ingprocess.pdf
If not, I would re-do it...
Ps-do the Organic Linings procedure if you have the standard install...
Rob Schroer
RV-7/N75WV
YIO-360-M1B
New Braunfels, Texas (KBAZ)
Old 04-09-2019, 03:15 PM
airguy's Avatar
airguy airguy is offline
If you've gotten any brake fluid contamination at all on the pads, the pads are nerfed and will need to be replaced. I did that once...
Garden City, TX VAF 2021 dues paid
N16GN flying 900 hrs and counting; IO360, SDS, WWRV200, Dynon HDX, IFD440, G5
Old 04-09-2019, 03:30 PM
RV6_flyer's Avatar
Tom
Dues paid
My RV-6 with 160 HP and Constant Speed prop will be 22-years old. The brakes are not strong enough to hold the airplane at full power.
I do NOT use the Cleveland recommended procedure for brake break-in. Our light aircraft with lots of power will create too much heat. I typically just taxi the aircraft to run-up using some light braking. I do my runup, fly around the pattern, then when all three wheels are on the ground, use the brakes to stop as fast as I can. I do a hard stop after landing using brakes about once a month to keep the brake pads conditioned.
Why do I not do a fast taxi with the brakes on? One friend almost caught his RV-8 on fire with a brake fluid leak that caught fire. It destroyed his wheel pant but his son was at his hangar, grabbed the fire extinguisher, put the fire out before anything else got damaged.
Gary A. Sobek
NC25 RV-6
Flying
3,400+ hours
Where is N157GS
Building RV-8 S/N: 80012
Old 04-09-2019, 05:35 PM
snopercod's Avatar
This is why I switched to Royco 782 synthetic brake fluid. It has a higher fire point (490F).
(2020 dues paid)
Old 04-09-2019, 11:12 PM
622BH 622BH is offline
Default 1900 RPM Max
Since brand new (I built it), my RV-9 with Matco breaks has not been able to hold the aircraft above 1900 RPM. If I persist in exceeding 1900, the airplane skids along the pavement.
Didn't take but a couple of times at that to realize I was never going to be able to do a full-power, breaks locked, short-field take off.
But with these planes that's just not a worry - for me at least.
Old 04-09-2019, 11:14 PM
Tracer 10 Tracer 10 is offline
Default Breaking in your Brakes.
I agree with Gary.
I have seen a lot damage due to overheating brake disks & linings as well as crystallized O-Rings in the caliper?s & resulting leaks due to heat damage. If your brakes are to powerful you may just end up on your back suspended by your 5 point harness.
CW4 (Retired) U.S. Army
A&P: I pay double dues (it's worth it)
Restored L2-M; flown 7 years & sold.
Flying Oregon RV-6
Old 04-14-2019, 10:15 PM
FNG FNG is offline
Thanks everyone for the good information!
Tom
Old 04-15-2019, 07:08 AM
blueflyer's Avatar
blueflyer blueflyer is offline
I would put on new pads and see what that does for you.
Old 10-18-2021, 07:49 PM
TSPARKER99 TSPARKER99 is offline
Tom
Dues paid
I recently purchased an RV-9A. One of the first things I noticed and continues to bother me is the weak braking, as compared to my Cessna 172. I pulled out the plans tonight to look at the geometry and I can immediately see why they are much weaker than expected. I am going to work on some ideas to improve them. I am surprised after so many iterations of the RV design that they are using such a poor brake and pedal geometry. The RV-12 looks to be even worse.
This is my first post on the forum, so I fully expect to get flamed for this one.
