Inadvertenly sent 12 volts down the ground wire to both roll and pitch servo's during my professional install. (backfed to pin 9 on servo) Does anyone know if I have damaged the servo's. It's Sunday and can't talk to anyone at trutrak.
The Gemini control head was luckily not present for this event so I simply got power to the servo's via the designed grounding pin. Going to Lakeland for tuesday and not planning on anymore "installing" until my return but would probably take the servo's with me if I knew they were damaged. Leaving this evening so if anyone out there knows I have damaged them for sure please let me know.
