Go Back   VAF Forums > Avionics / Interiors / Fiberglass > GPS
Old 03-29-2019, 11:50 AM
g3xpert's Avatar
g3xpert g3xpert is offline
Default Garmin FIS-B New Weather Products on Aera 660 and Aera 79X (Available 3/26/19)
Aera 79X software version 5.60, and Aera 660 software version 3.50 have been released and are currently available for download.
Aera 79X:
software download website: https://www8.garmin.com/support/down...ls.jsp?id=5349
Pilot's Guide (Rev G released March 2019): https://support.garmin.com/support/m...=en&country=US
Aera 660:
Software downloads available directly to device via WiFi.
Pilot's Guide (Rev E released March 2019): https://support.garmin.com/support/m...=en&country=GB
New Features:
? Interface support for GPS 175 and GNX 375.
? Added 4 new FIS-B weather products:
o Lightning
o Cloud Tops Forecast
o Turbulence Forecast
o Icing Forecast
Here are the currently available FIS-B weather products available when connected to a GDL 39/39R/39 3D, GDL 50/50R/52/52R, GNX 375, GTX 345/345R/45R:
Note: In current software, these features are only available over a Bluetooth connection. If you only have an RS-232 connection to your ADS-B receiver, it is recommended to add a Bluetooth connection to receive the new weather products
Levi Self
Garmin G3X Support
g3xpert@garmin.com
1-866-854-8433 - 7 to 7 Central Time M to F
Please email us for support instead of using Private Messaging due to the limitations of the latter.
Old 03-29-2019, 03:27 PM
bhester's Avatar
bhester bhester is offline
Thumbs up Good deal and timing
Just in time for SnF! Thanks!
It would really be nice to see a deal on databases. I have a G3X and a 660 I pay $149 I believe for my G3X database annual updates and I also have to pay that for my 660 annually. Any way we could get a deal if we have both of these and want to keep them current?
Bobby Hester - Builder/Pilot/A&P
Surfing the web from Hopkinsville, KY
N857BH RV7A XP-O360 - Garmin G3X ADS-B IN/OUT 2020 Compliant
Web site: http://www.newtech.com/bobbyhester/RVSite.htm
Dec. 2020 VAF donator - alot better than any magazine subscription
Old 03-29-2019, 04:07 PM
uk_figs's Avatar
uk_figs uk_figs is offline
Default # of BT connections
[quote=
Levi Self[/QUOTE]
Great news on the additional products, I have the GDL39 hardwired (RS232) to the 796 and BT to the iPhone and iPad, how many simultaneous BT connections does the GDL39 support? Is the hardwired connection support in the works?
Figs
Dave (Figs) (RV-7 N256F, Flying)
Dave's RV-7 Blog
Email me
Old 03-29-2019, 04:42 PM
Brantel's Avatar
Brantel Brantel is offline
Figs
2 BT plus 1 hardwired all at the same time.
Brantel (Brian Chesteen),
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 03-30-2019, 07:32 AM
uk_figs's Avatar
Default Disable RS232?
Brian, thanks for the input, next question is whether the BT and serial interfaces can run concurrently from the 39 or do you have to disable the 232 on port 1 to use the BT. If they can run concurrently I could choose on a flight basis whether to turn BT on or off. How many BT devices does the 39 store for automatics reconnect.
I assume the new products will show up in Garmin pilot also so the data will be available but the 796 is easier to use in flight (for me) as it is right below the PFD.
Figs
Dave's RV-7 Blog
Email me
Old 03-30-2019, 07:44 AM
g3xpert's Avatar
Post
Figs
Hello Dave,
Yes, you can run both the RS-232 and Bluetooth connections at the same time if you like.
All of the new FIS-B products are forecast, not live, except for lightning.
I think your plan of judiciously using Bluetooth is a good one. Personally I use forecast products for trip planning, but not in flight, so I don't even bother connecting up the Bluetooth unless there might be lightning out there to see. I have everything hardwired.
Steve
Garmin G3X Support
g3xpert@garmin.com
Old 03-30-2019, 11:15 AM
Tooch Tooch is offline
Default RS-232
Hi Steve,
Are there plans to make the new weather products available over the hardwired connection from my GDL-50 to my 796 in the future?
Old 03-30-2019, 07:18 PM
DarylT's Avatar
DarylT DarylT is offline
Talking
Dave it will only work on Nose gear RV aircraft!
Daryl Tolliver
VAF 1086
Yes: I paid my =VAF= membership dues for 2021
RV-7A - N754RV: Status - Pink Slip is In! First Flight 8/23/12 - My First Flight 9/24/12!
Home from GloCustom for Paint! 3/16/13
1046 hours and climbing
9th Condition Inspection complete 10/31/2021
Superior XP IO360 (180 HP), Hartzell Blended Airfoil, AF-5400 EFIS panel, Garmin Aera 660, TruTrak Vizion 385 AutoPilot, Dual Pmags
Houston, TX
Dry Creek Airpark (TS07)
http://www.rv7a-factory.com
Old 04-01-2019, 12:25 PM
Plummit's Avatar
Plummit Plummit is offline
The instructions said to use web updater but I get a 404 message when I click on the link.
-Marc
Aera 79X:
Aera 660:
New Features:
o Lightning
o Icing Forecast
Levi Self
RV-10
N814RV
2021 Donation Made
Old 07-17-2019, 02:25 PM
uk_figs's Avatar
Default 796 bluetooth to IOS
I guess the 796 still does not support IOS Bluetooth (tried today and it connects but wont pair), is it in the plans to connect the IOS Garmin pilot to the 796 somehow to allow flight plan transfers etc?(i.e via the GDL39 connection and the hard wired link?).
Also with this capability currently using the BT link from the 796 to the GDL39 it limits the GDL39 to only one other BT connection (I normally have the phone and ipad connected).
Figs
Dave's RV-7 Blog
Email me
