Old 03-28-2019, 12:23 AM
AX-O's Avatar
AX-O AX-O is offline
Default Roll your own Mag cover
I am getting ready to build a motor and wanted to step up in class during the portions of the build where catastrophic FOD inside the motor could occur.
Specifically the portion where I put a piece of cardboard where the mags and other accessories go.
So since I have been designing things on Solidworks for the plane, figured I could give this a try. The studs on the case are too long. I will fix that later. This is just a trial fit. I rounded the edges on the cover so I could easily grab it with my fingers to remove it. I also re-enforce the area with a flange in case it got smacked, it did not fall apart. The part is strong like bull.
Designed cover on Solidworks
Code transferred to Simplify 3D
Printing
Finished parts
Axel
RV-4 fastback thread and Pics
VAF 2020 paid VAF 704
The information that I post is just that; information and my own personal experiences. You need to weigh out the pros and cons and make up your own mind/decisions. The pictures posted may not show the final stage or configuration. Build at your own risk. Further more, these are my opinions and not those of my employer.
Old 03-28-2019, 12:53 AM
G-force's Avatar
G-force G-force is offline
Nice. If the printer had the vertical capacity, why not build up tubes around the studs so you could simply use a nut to secure? Or are you saying those studs are not right for you final assembly anyway and have to come out reguardless.
Mike Sumner
Castaic, Ca
Old 03-28-2019, 08:52 AM
AX-O's Avatar
Studs are not right. They came set up for mags with the 2 inch spacer. I will be using pmags so the studs are way shorter.
Axel
Old 03-28-2019, 01:52 PM
Timberwolf Timberwolf is offline
Nice job for a temporary cover...just wanted to stress the importance this is for a temporary thing and not to be left on for actually running the engine
Shane
RV-6 IO-360 Angle valve, G3X touch
Murphy Moose M14P flying
Aero Engineer, A&P
Old 03-28-2019, 02:03 PM
AX-O's Avatar
Originally Posted by Timberwolf View Post
PLA? Not worth risking a $30K engine with a 10 cent part. 3D Printers have their place, but not in this application..... even if that was made of nylone
I think you missed the point. This is a cover to be only used during construction. Not operation.
Axel
Old 03-28-2019, 02:06 PM
Ironflight's Avatar
VAF Moderator / Line Boy
So much nice than the ones I hacked out of some old sheet metal I found behind the workbench Axel...nice job!
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 03-28-2019, 02:26 PM
bhassel's Avatar
bhassel bhassel is offline
I'm curious, how long did it take to print those?
Bob
Bob Hassel
NM
Subscription Paid for 2021
Home is where the hanger is...
Old 03-28-2019, 02:50 PM
AX-O's Avatar
Bob
I think about 35 minutes or so for 1. certainly not fast.
Axel
Old 03-28-2019, 06:25 PM
BMC_Dave BMC_Dave is offline
Heh, not too long ago printing those would have been prohibitively expensive. Amazing how this technology has progressed.
