Go Back   VAF Forums > Avionics / Interiors / Fiberglass > GPS
Old 03-25-2019, 12:20 PM
g3xpert's Avatar
g3xpert g3xpert is offline
Default New Product Announcement: GPS 175/GNX 375 IFR Navigators (3/25/19)
We are extremely excited to announce our new GPS 175 and GNX 375 as the latest addition to the Garmin product line of touchscreen IFR navigators.
The GPS 175 IFR GPS navigator provides WAAS/LPV approach capability to your aircraft in an affordable, compact design that saves weight and panel space.
https://buy.garmin.com/en-US/US/p/577202
The GNX 375 builds on the features set of the GPS 175 and includes a built-in transponder providing ADS-B Out compliance and dual link ADS-B In.
https://buy.garmin.com/en-US/US/p/577174
The GPS 175 and GNX 375 offer a beautifully blended user interface with a dual concentric knob and a touchscreen. The touchscreen allows for quick data entry and key features such as graphical flight plan editing while the knob allows for quick page switching and an alternate means of data entry. For those of you with experience in the Garmin GNS series or G3X systems, the page selection via the outer knob will make you feel right at home.
These navigators are filled with the Garmin features you have come to love such as FastFind which simplifies flight plan entry by applying predictive logic to suggest airports and waypoints using current GPS location, and Smart Airspace which makes it easier to identify pertinent airspace on the moving map. The addition of SafeTaxi® airport diagrams display runways, taxiways, Fixed Based Operators (FBO’s), hangars and more relative to the aircraft’s location on the airport surface. The design maximizes usability of the 2-inch form factor by use of a high-resolution display which covers almost the entire vertical dimension of the unit.
GNX 375 Screenshot of weather overlay on map
GNX 375 Screenshot of SafeTaxi
With a MAP price of $4295 including GPS antenna, rack and connectors the GPS 175 is designed to fit your budget. Making room for the GPS 175 in your stack is simple with the slim 2-inch vertical form factor. With a behind panel depth of under 7 inches, installing the GPS 175 in your panel requires minimal space. At a total weight including rack and connector kit of only 1.9 pounds, the decision to include an IFR Navigator in your panel has never been easier.
The GNX 375 has a list price of $7995 including GPS antenna, rack, and connector kit. The GNX has a behind panel depth of 9 inches, over an inch shorter than the GTX 345. At only 4.4 pounds including rack and connectors, significant weight savings is available by combining the IFR navigation function with your transponder. This combined functionality also saves installation time by reducing the number of wires and total components required for installation. By providing both ADS-B In and Out in one unit, the GNX also requires only one monopole antenna.
The GPS and GNX integrate seamlessly to the G3X Touch system using a GAD 29 ARINC adapter. The G3X Touch overlays the flight plan from the navigator on the large moving maps in the 10.6 inch and 7 inch displays as well as deviation indications on the Primary Flight Display (PFD). When paired with the GNX 375, the ADS-B traffic and weather can be displayed on the G3X Touch System and the transponder in the GNX can be optionally displayed and tuned via the G3X Touch system.
Built-in Connext® cockpit connectivity gives you the benefits and efficiencies of a wireless cockpit, enabling wireless flight plan transfer via Bluetooth® to and from compatible portables and mobile devices running the Garmin Pilot™ and FltPlan Go applications. GPS position information and back-up attitude can also be used by compatible products. Because the GNX 375 has an integrated ADS-B transponder and dual link ADS-B In, pilots can also view ADS-B traffic and weather on compatible mobile devices and portables.
The GPS 175 and GNX 375 units have received TSOA and are expected to start shipping in April. A free Garmin GPS 175/GNX 375 trainer app is also available for download on Apple mobile devices, which allows customers to experience the feature set of these navigators. https://itunes.apple.com/us/app/garm...r/id1454577309
Levi Self
Garmin G3X Support
g3xpert@garmin.com
1-866-854-8433 - 7 to 7 Central Time M to F
Please email us for support instead of using Private Messaging due to the limitations of the latter.
Old 03-25-2019, 01:42 PM
jbDC9 jbDC9 is offline
Holee cr@p! All of a sudden I?m really glad that I?ve delayed picking a solution for ADSB.... this is awesome. I want one...
John Bixby
RV-8 QB sn 82030 - 1st flight Nov 2006
O-360-A1D/CS/Pmags
1850 hrs
Houston, TX
Old 03-25-2019, 01:45 PM
Interesting product developments indeed!
How much commonality is there between the 650 and 175 software versions?
I ask because we know it has taken several iterations for the 650 to achieve some of the navigation functionality that was available in older navigators like the GNS480. I'm wondering if the 175/375 units have their software baselined on the current 650, or whether they are a separate stream that will go through a similar iterative process to reach full functionality?
Old 03-25-2019, 01:52 PM
ppilotmike's Avatar
Default Love it!
I also would like to know how these units compare to the 650/750. Do they offer the same features, but in a smaller, lighter unit, without the big screen interface?
Mike Rettig
VAF Dues Current
RV-10 - Working on engine / prop installation
Old 03-25-2019, 02:00 PM
g3xpert's Avatar
The GPS 175 should be compared to a GTN 625, as the GTN 650 has a built in NAV and COM which makes it a completely different product.
The level of performance and features is largely the same with a few key exceptions. The GTN works better when you have dual navigators as they will share flight plan with the other navigator. Also the GTN has VNAV and while the GPS 175 has VCALC. I haven't done a complete side by side comparison and there may be some other minor differences.
The GPS 175 also has a smaller display, but is still a very capable IFR navigator.
Levi
Garmin G3X Support
g3xpert@garmin.com
rvbuilder2002's Avatar
Levi,
All of the press releases I have seen price the 175 at $4995. Which price is correct?
Scott McDaniels
Hubbard, Oregon
FAA/DAR
Old 03-25-2019, 02:20 PM
g3xpert's Avatar
Hi Scott,
The list price of the GPS 175 is $4,995, while the minimum advertised price is set at $4,295. This unit carries both a list and MAP price as do many of the experimental products.
Best Regards,
Brad
Garmin G3X Support
g3xpert@garmin.com
Old 03-25-2019, 02:35 PM
SmilingJack's Avatar
Does this give you the capability to replace a GDL39 for ADSb IN and display weather and traffic via Bluetooth on an iPad?
Garmin Pilot and Foreflight?
John Mastro
RV-8 (SOLD)
10 years of Awesomeness!
Old 03-25-2019, 02:36 PM
g3xpert's Avatar
What is implied but not clearly stated is that the GPS 175 can be purchased "over the counter" even for installation in certified aircraft. The over the counter units typically have both a list price and a minimum advertised price.
The E-AB world has some exceptions as you can purchase a GTN and other items which cannot be purchased over the counter, except by E-AB customers.
Levi
Garmin G3X Support
g3xpert@garmin.com
Old 03-25-2019, 02:38 PM
g3xpert's Avatar
If you have a GNX 375, it contains the ADS-B receiver and bluetooth. So, yes, if you buy the GNX 375, you would not need your GDL 39. The GPS 175 does not contain an ADS-B receiver.
Levi
Garmin G3X Support
g3xpert@garmin.com
