Old 03-25-2019, 12:19 PM
g3xpert's Avatar
g3xpert g3xpert is offline
Default G3X Touch is now CERTIFIED (3/25/19)
Since so many of you have interest in the G3X Touch system and have interests outside of E-AB aircraft as well , I wanted to let you know that Garmin has received AML STC on nearly 500 single engine aircraft models. Check out the Garmin website to see a full list of the supported models.
https://buy.garmin.com/en-US/US/p/682215
The G3X Touch offers a variety of scalable panel configurations and a superior feature set that includes Primary Flight Display (PFD), Multi-Function Display (MFD) and optional Engine Information System (EIS). Wireless connectivity and synthetic vision come as standard, as well as options such as display redundancy, advanced autopilot compatibility, and affordable databases.
The G3X Touch system is representative of Garmin’s experience in integrated flight deck technology, boasting a clean and sleek appearance and a resilient, high-resolution display which has proven itself in thousands of installations in experimental aircraft. The touchscreen offers an intuitive user-friendly interface. Through any combination of the touchscreen or dual-concentric knobs, pilots can efficiently perform common in-flight functions like direct-to navigation, setting altitude pre-select or radio tuning. Pilots will also appreciate the seamless in-flight experience behind G3X Touch as the user interface is harmonious with multiple Garmin products, such as the new GPS 175/GNX™ 375 and GTN™ 650/750 navigators.
Garmin offers four different display configurations.
• A single GDU 470 7” portrait display system starting at $7,995 (no EIS)
• Two GDU 470 7” portrait displays starting at $12,865 (EIS optional)
• A single GDU 460 10.6” landscape display system for $9,995 (EIS optional)
• A GDU 460 10.6” display and a GDU 470 7” display system $14,865 (EIS optional)
Each G3X Touch system includes a GSU 25D ADAHRS, GMU 11 Magnetometer, GTP 59 OAT Probe, and installation/connector kits. Adding EIS for a 4-cylinder engine starts at $3000 and adding EIS for a 6-cylinder engine starts at $3400. The EIS system includes the GEA 24 engine interface, engine probes, and sensors. The GDL 50R, 51R, and 52R series of ADS-B and SXM receivers is also included in the AML STC as an option starting at $795. All products installed under the Garmin AML STC have received PMA.
The G3X Touch suite offers an impressive array of standard features that give pilots greater situational awareness throughout every phase of flight. Synthetic vision (SVX™) comes standard on all G3X Touch displays. Capable of serving as a standalone VFR navigator, the G3X Touch provides benefits that help further situational awareness in visual conditions with features like vertical navigation (VNAV). Wireless connectivity is also available as standard. Wireless flight plan transfer, the sharing of traffic, weather, back-up attitude information and more with a compatible tablet or smartphone are all available via Garmin Connext®
The G3X Touch flight certificated system can interface with a variety of optional equipment including:
• For complete IFR-approach compatibility, customers can pair the G3X Touch with up to two Garmin GPS navigators and Nav/Comms, including the new GPS 175/GNX 375, GTN 650/750, GNS™ 430W/530W, GNS 480, SL 30/40, and GNC® 255.
• The GFC 500 autopilot integrates seamlessly with the G3X Touch certified system and provides a state-of-the-art 3 axis autopilot with integrated electric pitch trim. The GFC 500 AML STC has been updated to include the G3X Touch as an attitude source and display of flight director for the GFC 500 autopilot. The GFC 500 does not require the G5 electronic flight instrument when installed with G3X Touch. The GFC 500 is currently available as an option for select models of the Beechcraft Bonanza, Cessna 172/182/210, Grumman AA-5, Mooney M20 and the Piper PA-28 with additional certifications in progress. For a comprehensive list of supported aircraft, visit www.garmin.com/GFC500.
• Fly fully-coupled instrument and visual approaches when the G3X Touch is paired with the GFC 500 autopilot and a GPS 175/GNX 375 or GTN 650/750. If you don’t break out, you can fly fully-coupled go-arounds during missed approach sequencing.
• The G5 electronic flight instrument can be utilized as an all-in-one back-up instrument2 to the G3X Touch flight display, offering superior redundancy and the sharing of attitude information, air data, baro sync, and miscompare alerts. In the event of failed source between the G3X Touch and G5 attitude or air data sources, the GFC 500 autopilot will choose the best available source and continue to function normally.
• Pilots can receive and display the benefits ADS-B In via the new GNX 375, GTX™ 345 or the GDL® 50R/52R. ADS-B-enabled features such as patented TargetTrend™ and TerminalTraffic™ are also available with these products.
• With the GDL 51R/52R, pilots can receive and display SiriusXM aviation weather and listen to audio entertainment with a compatible subscription.
• VFR sectionals and IFR enroute charts display pertinent information pertaining to VFR/IFR flights, and geo-referenced instrument approaches improve situational awareness by overlaying own-ship position information on the instrument approach chart.
• Up to two Comm radios can be supported and controlled by G3X Touch, including the GNC 255 Nav/Comm and the GTR 225 Comm, as well as the GTN 650/750.
• Display primary engine information with the addition of the GEA 24 and applicable engine sensors. The EIS system includes engine gauges with color bands, alerts, a fuel computer and other vital information. Piston engines of up to 6 cylinders are supported.
• When interfaced to a compatible Garmin transponder, the G3X Touch offers transponder control and display using the large touchscreen interface.
• The GTS 800 active traffic system can interface with G3X Touch, offering added protection and visibility while operating in high-density airspace and traffic environments.
Your G3X Touch Certified system can be purchased and installed through the Garmin Authorized Dealer network. There is no additional cost for the STC. Deliveries for new orders are expected to begin in early April. Come and see the G3X Touch at the Sun ‘n Fun International Fly-In & Expo, Apr. 2-7, 2019 in Lakeland, Florida.
Levi Self
Garmin G3X Support
g3xpert@garmin.com
1-866-854-8433 - 7 to 7 Central Time M to F
Please email us for support instead of using Private Messaging due to the limitations of the latter.
Old 03-25-2019, 12:49 PM
bkthomps bkthomps is offline
would it be fair to assume now that the software release cycles will slow to molasses?
or will you maintain a separate software branch for experimental?
As an experimental user, I'm hoping the latter, as an investor/shareholder, i would say the first is the likely scenario
Old 03-25-2019, 01:09 PM
g3xpert's Avatar
No, we are not expecting any slow down of software features. The G3X Touch will follow the same process for how we currently do G5 software. Team X continues to move forward with software for E-AB and our certification team lags a little behind with the certification aspects.
We are getting ready to release new G3X Touch software this week which has some new features not yet available to the certified G3X Touch customers. E-AB will always get the newest features!
If you have followed along for the past couple of years, the G5 feature set has expanded greatly since it was certified. A larger user base is a good thing!
Levi Self
Garmin G3X Support
g3xpert@garmin.com
Old 03-25-2019, 03:27 PM
Paddy's Avatar
Paddy Paddy is offline
Default G3X Non-Touch
Any update on the availability of a software update to the G3X non-touch product to enable the most recent GTN vertical navigation capability?
RV-10 N415JS
Slow build kit #40874
Homebuilt Kit Champion Oshkosh 2019
Atlantic crossings: 2
Old 03-25-2019, 03:29 PM
bkervaski's Avatar
bkervaski bkervaski is offline
This is great news! Congrats.
RV-14A #140376
N196 (Flying)
2019 Bronze Lindy
Old 03-25-2019, 03:35 PM
SmilingJack's Avatar
G3Xpert,
You don?t mention the GDU 450 7? Landscape display for the certified aircraft.
Is that product goin to be phased out?
Thanks for the great product upgrades!
John Mastro
RV-8 (SOLD)
10 years of Awesomeness!
Old 03-25-2019, 04:21 PM
Thermos's Avatar
Thermos Thermos is offline
Very cool!
Levi/G3xpert, what's the difference between the certified GSU-25D and the experimental GSU-25?
Dave
Dave Setser
CFII/MEI
EAA Technical Counselor/Flight Advisor
RV-7 N701ED Flying!
Nashua, NH (KASH) / Plymouth, NH (1P1)
Old 03-25-2019, 04:46 PM
1001001's Avatar
1001001 1001001 is offline
Default AML
You have to go here for the approved model list.
Old 03-25-2019, 04:51 PM
1001001's Avatar
Great news! Interesting to see the PA-24 and PA-32 listed but not the PA-30 or PA-34.
Old 03-25-2019, 05:42 PM
RV7AJeremy's Avatar
RV7AJeremy RV7AJeremy is offline
Where is the list of STCs? Didn?t find it in the link above.
Jeremy
ATP, CFI, CFII
RV-7 N424JD KCHD
Carbon Cub EX2 N852AZ KCHD
EAA Tech Counselor
2017 Bronze Lindy
