Old 03-19-2019, 12:51 PM
fbrewer fbrewer is offline
Default Leaky Brake Fittings
OK, so we have leaky fittings on the right side brakes.
We've tried tightening the plastic fittings without stripping the threads -- no dice. Still leaks.
I think I want to replace the semi clear tubing and replace with the black hose and new fittings. Where is the best place to buy these replacement parts?
Any other suggestions to my leaky brake fitting problems?
Old 03-19-2019, 01:11 PM
you could up grade to teflon and save some weight over the H8794 black hoses
Tom
RV7A Tail Kit Completed, Fuse started-Pay as I go Plan, on hold while we develop new products for RV builders
Ridgeland, SC
Old 03-19-2019, 01:19 PM
Tom,
I see on your website dual brake hose kits. Are those hoses stainless braid Teflon hose?
What is the cost of the kit?
Old 03-19-2019, 01:23 PM
pazmanyflyer's Avatar
pazmanyflyer pazmanyflyer is offline
If your looking just to replace the plastic fittings then call Vans and order their F69-F-04X02 brass elbow brake assembly. Mine is a -7 but this shouldn't matter as I think all Vans planes use these. See upper left corner of build sheet for specifics.
Here's the link to zoom in.
https://photos.google.com/album/AF1Q...Rz04O4J18QNJvW
Carlos in Arizona
EAA Chapter 538 www.chapters.eaa.org/eaa538
Wittman Tailwind W8 N53CH (built & sold)
Pazmany PL-1 N2029 (bought & sold)
RV7 - N537TC (reserved & building)
Emp, Wings & Fuse done - working on FWF
"The air is an extremely dangerous, jealous and exacting mistress. Once under the spell most lovers are faithful to the end, which is not always old age." - Winston Churchill
Old 03-19-2019, 01:48 PM
Mel's Avatar
Mel Mel is offline
The nylon tubing works fine, but the brass fittings work MUCH better than the plastic.
IMO the plastic fittings should be used only on the reservoir (non-pressurized) side.
Also, when using the brass fittings, don't forget the brass inserts. They are a VERY important part of the fitting.
Mel Asberry, DAR since the last century. Over 1,000 certifications accomplished. Discount for Veterans, Law Enforcement, Fire Fighters.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 03-19-2019, 02:34 PM
sjhurlbut sjhurlbut is offline
Default Brake Lines
I never use plastic lines after multiple issues in the past. Its very cheap to upgrade to flexible AN3 pre made hoses. Give Tom at TSFlightlines a call. Ask for AN3 fittings with narrow brake lines. Easy upgrade and trouble free forever.
Heres a pic from a while ago. I use Grove reservoirs mounted to pedals.
Visit and subscribe to Stu's Aircraft Factory on
https://www.youtube.com/channel/UCGQ..._as=subscriber
"Stu"
Snowbird #?
Moose Jaw, SK
7A #70015 - C-FZQX - built - sold
7A #71629 - C-FSIS - built - sold across Atlantic
7 #70215 - C-GOJU - flying - sold
7 #70703 - C-GMIY - flying - sold
6 #60119 - C-FHBZ - built - Airventure 2016 Bronze Lindy - sold
8 #82842 - C-FSBG - built - sold
4 #2723 - C-GVBX - built - flying!!!!
Old 03-19-2019, 02:58 PM
snopercod's Avatar
What Mel said! Going one step further, I recommend the Parker Brass Compression Fittings with the hex nuts rather than the knurled ones. ACS calls them "SAE fittings". Definitely use the inserts, which come in different diameters depending upon the wall thickness of your tubing.
(2020 dues paid)
Old 03-19-2019, 08:58 PM
rapid_ascent rapid_ascent is offline
Hey Frank,
I'm building braided lines for my brake lines. I think I probably have the brass fittings that you need that came with my kit. PM me with what you think you need. I'll check what I have when I'm out at my hangar this weekend. I can drop them in the mail to you.
Ray
Ray Tonks
2022 Donation Paid
Titan IOX-370, Dual PMAGs, 9.6:1 Pistons, FM-150
RV-7 Fuselage in progress
* Cabin Interior - In progress
RV-7 SB Wings
* Both Wings fully skinned
* Fuel Tanks Complete - No leaks finally
* Ailerons Complete
* Flaps Complete
RV-7 Empennage - Complete (a little fiberglass work left)
Vans Training Kit # 2 - Complete
RV-7 Preview Plans
Vans Training Kit #1 - Complete
EAA Sheet Metal Class - Complete
Old 03-20-2019, 09:24 PM
RViter RViter is offline
What Mel said... I missed that detail 'once' and found out quickly they leak.
gary
RV-6A QB Tip-Up, 1st Flight 3/18/17
O-360-J2A (modified & F/I), Sensenich FP (cruise)
VP-X Sport, Dynon SkyView, VFR day
(FFZ) Mesa, AZ - N234GB -
www.mykitlog.com/garyc
Old 03-21-2019, 12:26 AM
lr172 lr172 is offline
Those two lines have no pressure other than gravity induced. However, there is constant movement of the tubing and those plastic fitting are simply not up to the task. Those plastic fittings seal via an oring that has probably dried up and shrunk. The simple fix is to replace the orings. However, I would recommend replacement with the specified brass fitting with ferrules and inserts.
Larry
