Go Back   VAF Forums > Model Specific > RV-14
Old 02-18-2019, 04:41 PM
Moeggeploeg Moeggeploeg is offline
Default RV 14 VFR day/night panel, feedback please
I shall appreciate feedback/ideas on the proposed panel.
Especially the outlay of the screens and switches. What to omit/add/move.
Setup to pilot from both sides.
Future panel upgrade if mission changes.
VPX for breakers.
Remote transponder.
Two axis auto pilot.
Tosten 4 f(x) stick bought, so limited to 1)trim aileron, 2)elevator and 3)radio flip flop as well as 4)PTT.
Electronic CO sensor displaying on the G3X.
How necessary is an audio panel?
How usefull is a TOGA switch?
https://i.postimg.cc/LXL86vtT/Panel-JPEG-18-Feb19.jpg
Old 02-18-2019, 05:01 PM
Carl Froehlich's Avatar
Carl Froehlich Carl Froehlich is offline
Some thoughts:
- Delete the panel compass. Move the G5 (or perhaps a D10A) to that postion.
- As you might want to modify the panel for IFR, consider leaving room high in the center section for a GTN-650. Odds are if you do upgrade you will just buy new aluminum blanks so no worries for now.
- Delete the map box.
- As you note the Tosten grips limit your options. For example the Infinity Grips provide for all that you list plus the flap switch, TOGA button and more important an Autopilot disconnect. For your grips I recommend changing the comm flip/flop button to Autopilot disconnect.
- Make sure you understand the VPX product and follow the install instructions on providing backups.
- The Audio Panel can be deferred until upgrade. I assume the GTR radio has an internal intercom like the Dynon radio, so that will do for now.
Carl
Old 02-18-2019, 05:05 PM
MED MED is offline
The toga button is used for aborted instrument approaches. You won?t need it unless you decide later to go IFR.
MED
140236
N435MD
Miss March 2020
Old 02-18-2019, 06:28 PM
azflyer21 azflyer21 is offline
Although you want to fly from left or right side, I would consider putting the start button and master switches on the left side to keep away from other switches.
Kevin Lippert
RV-14A N1402 Flying 03-2020
Phase 1 Complete 07-12-2020
YouTube Channel
Build Log
Zenith 750 completed 2016 -
Sold
Old 02-18-2019, 06:37 PM
N941WR's Avatar
N941WR N941WR is offline
I assume your starter button and mag switches will be on the left. If that is the case, move the P-mag test switches over there as well. You don't want to risk hitting them in flight.
Same with the Avionics Master, separate it, even a little bit, from the other switches so you don't accidently turn off your instruments at night, on approach, when reaching for the fuel pump or lights.
It is good you have a cigarette lighter power port but I would also add two USB power ports to the right of it and not put in the center console.
Dump the compass. That close to your EFIS means it may never work correctly. Besides, you are also going to have the G5 has your backup. (Think about replacing the G5 with a Dynon PocketPanel as the PocketPanel does not need to be connected to the pitot or static system and being from a different manufacture, a "common" bug won't take both down.)
Good luck, that is one check of a Day/Night panel!
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 02-18-2019, 08:05 PM
mulde35d's Avatar
mulde35d mulde35d is offline
Default Compass
Small bit of thread creep, but it goes to the two comments to remove the compass. My understanding may be off, but the heading is provided by the magnetometer not the AHRS or G5. If running off the backup battery on the G5 is the last ditch recovery mode, I would think a standby compass would be needed for magnetic heading information. Am I wrong that it wouldn?t be provided any other way while operating solely on a G5 battery with no other power or inputs?
Jon
http://www.mykitlog.com/mulde35d
RV-14A Sold
RV-10 Empennage - Searching
Wing - On Order
Old 02-18-2019, 09:28 PM
Av8rRob's Avatar
Av8rRob Av8rRob is offline
I would recommend moving those switches to the left and right of the panel to free up space in the center radio stack for future use. Ya never know.
Rob Lasater
Rv-14 flying baby, yeah.
Paid Dec 2020
Old 02-18-2019, 09:39 PM
MConner MConner is offline
Agree with the comments, compass is not needed there. Maps are on an IPad now, lose the map pocket. You will find plenty to fill that panel space.
Mark
RV-10
Bought not built
EAA 180
48X
Old 02-18-2019, 10:32 PM
g3xpert's Avatar
g3xpert g3xpert is offline
The GTR 200 has a best-in-class built in intercom. For a two seat aircraft like the RV-14, if you have a single COM, VFR aircraft the GTR 200 cannot be beat for a COM/Intercom combo, except by the GTR 200B which has all the great features of the GTR 200 plus Bluetooth. An audio panel is not necessary.
There are several questions regarding the G5 in this thread. I would like to point out a few things to think about.
  • The G5 was not designed to just be a low cost EFIS, it was specifically designed to be a backup for G3X. Careful consideration was given to using different hardware (processor, sensors, etc) and software algorithms.
  • The G5 can display attitude on the large G3X GDU if there is a GSU 25 failure.
  • The G5 can run the Garmin autopilot if there is a GSU or GDU failure
  • The G5 can have its own backup battery providing over 4 hours of backup attitude.
  • If the G5 loses the GMU 11, it will still display ground track in place of heading. This is arguably more useful than magnetic heading information in the case of an emergency.
Levi Self
Garmin G3X Support
g3xpert@garmin.com
1-866-854-8433 - 7 to 7 Central Time M to F
Please email us for support instead of using Private Messaging due to the limitations of the latter.
Old 02-18-2019, 10:56 PM
infltc2s infltc2s is offline
Default RV-14 Panel
This may be an over kill for what your looking for, anyway this is what I did.
RV-14 Flying
N352AL
Texas
