Old 02-02-2019, 05:02 PM
ron sterba ron sterba is offline
Question Condition inspection RV9A/ compression tests.
Working on my condition inspection in my logbook for engine I have a note with my compression tests from last year that indicate satisfactory with AC 90.116-98. I wanted to read that but I cannot find it I am assuming it is a advisory circular. When checking on the Internet I show no results found. After checking my Lycoming manual I am not finding a set of values for compression test. Help! Ron in Oregon
Old 02-02-2019, 05:59 PM
RV6_flyer's Avatar
Here is a link to the Lycoming website that has the instructions for a compression check. The instructions are given in latest version of Service Instruction 1191.
Gary A. Sobek
NC25 RV-6
Flying
3,400+ hours
Where is N157GS
Building RV-8 S/N: 80012
Old 02-02-2019, 06:07 PM
Bicyclops Bicyclops is offline
This is mostly aimed at Continental engines but makes good sense for Lycomings as well:
https://www.avweb.com/news/savvyaviator/188758-1.html
The TCM service bulletin gives more guidance than the Lycoming SB about how to interpret the results of the compression test.
Ed Holyoke
Old 02-02-2019, 09:48 PM
Mycool's Avatar
Mycool Mycool is offline
Default Article
That was a great article, thanks for sharing Ed.
US ARMY VETERAN (75th & 1st 509th Airborne)
CFI, CFI-I, MEI, MEI-I, A&P
RV Transitional trainer
RV9A - FLYING
RV3 ?a? - FLYING 200+MPH
Onex - Building
Q200- Rebuild in progress
Wheeler Express - Sold
Grumman AA1-C - Sold
Grumman AA5 - Sold
Old 02-03-2019, 01:39 PM
Thanks Gary and Ed, excellent reading I might add! Perfect for my #s. /80. Just curious any body know whatAC 90.116-98 is or was. Thanks
Cheers
RV9A
RON in Oregon
Old 02-03-2019, 02:48 PM
krw5927 krw5927 is offline
Ron, you probably wrote "AC 90.116-9B", not "-98". AC 90.116 is the Advisory Circular on the Additional Pilot Program (guessing you took advantage of this since there are notes as such in your logbook).
Section 9B is "Powerplant Testing". No instructions for compression check, just guidance that you should perform one.
Kurt W.
RV9A
FLYING!!!
Old 02-05-2019, 05:10 PM
Thanks Kurt, so “8” is a “B” and it is in fact a Advisory Circular. You pushed my button of Curiosity on taking advantage of 90.116. What’s special here?��
Ron RV9A twin Dynon Skyviews
