Go Back   VAF Forums > Model Specific > RV-14
Old 02-02-2019, 01:14 AM
Nashman Nashman is offline
Default Newbie question: skin dent
Just starting out on my VS and I made my first (of many I'm sure) goof. Flipped VS-706 upside-down and when I wrapped the skin, the rib created a small but visible dent. I should have known better. I'll probably order a new skin to be safe, but would be helpful to get a second opinion. Am I going overboard or is this going to bother me every time I look at it?
https://static1.squarespace.com/stat...ad?format=500w
Mike
Old 02-02-2019, 01:31 AM
nzrv8's Avatar
nzrv8 nzrv8 is offline
You should be able to gently work that dent out Mike. It looks minor to me. It?s good to set yourself high standards at the start, but mentally prepare yourself for much bigger mistakes as the build progresses
Paid up - Sep 2021
Old 02-02-2019, 05:36 AM
Tom023 Tom023 is offline
Dent? What dent? That is a character line that makes the plane uniquely yours. As Hugh alludes to, you?ll know it when you really make a mistake and you will. I have several that have long been forgotten.
RV14A #140083
Flying! 8/12/19
2020 Donation
Old 02-02-2019, 06:49 AM
Tom Martin Tom Martin is offline
Spoon trick. Take a normal table spoon, cover the bottom with oil. Now place your dent over a metal plate, or a bucking bar. With your thumb in the spoon work it over the bump. Typically this will hide most small imperfections.
Tom Martin RV1 pilot 4.6hours!
CPL & IFR rated
EVO F1 Rocket 1000 hours,
2010 SARL Rocket 100 race, average speed of 238.6 knots/274.6mph
RV4, RV7, RV10, two HRIIs and five F1 Rockets
RV14 Tail dragger
Fairlea Field
St.Thomas, Ontario Canada, CYQS
fairleafield@gmail.com
Old 02-02-2019, 07:21 AM
Girraf Girraf is offline
Looks like that may have been caused by not tapering the nose of the rib. You won't find that instruction in the plans anywhere but read enough build logs and you'll see that feathering sharp corners on nose ribs where the nose rib flange ends will minimize the chances of that happening.
Agree with previous comments, this is way minor and certainly doesn't warrant replacing the skin.
Sage advice to heed now is whenever you make a mistake, leave the shop and come back tomorrow. Mistakes have a way seeming not so tragic the following day.
Vintage Cherokee 160
RV-7:
Empennage complete
SB Wings to QB stage
Fuselage in progress
Finish kit/Engine/Prop Ordered
Old 02-02-2019, 08:59 AM
kiljoy's Avatar
kiljoy kiljoy is offline
If I had ten dollars for every imperfection I'd caused I'd be able to pay for the plane
Just wait for the rudder!!!
Dues paid (2020)
RV-14 #140394
Empennage - done(ish)
Wings - done(ish)
Fuselage - done(ish)
Finishing Kit - Somewhere in there
YouTube Build Channel
Old 02-02-2019, 09:31 AM
kbalch's Avatar
kbalch kbalch is offline
This is absolutely in the -14 plans; it's explicitly called out in multiple sections.
Ken
RV-8 N118KB (#81125) - Sold
RV-14A N114KB (#140494) - Sold
RV-14A.com
N114KB Build Site
Old 02-02-2019, 09:52 AM
Thanks for the words of encouragement.
This, and a night's sleep and I'm realizing that the next step is to bang on the entire structure with a rivet gun -- what could possibly go wrong?
Old 02-02-2019, 04:40 PM
Oh yeah it totally is...my bad. Section 5.2 - Rib Flange Faceting!
I just closed my elevators in the last few days and if I had not given Section 5 another scan (which I do periodically), I would have forgotten the RTV on the trailing edges of the stiffeners. There is no reminder to do that in the section of steps for riveting the elevators shut.
RV-7:
Empennage complete
Old 02-04-2019, 01:13 PM
MJarreau MJarreau is offline
Default Hugh is Right
..mentally prepare yourself for much bigger mistakes as the build progresses
My (personal) skin gets thicker every time I have a small success
Mike
DUES REMINDER: JAN 2022
