Old 01-29-2019, 01:18 AM
pilot_tender pilot_tender is offline
Default RV-8 - #83674 - N8SA
I am building a RV-8 and have reserved the tail number 8SA. I have been documenting the build so far in time lapse video on YouTube. The Horizontal Stab and Vertical Stab videos are just the time lapse video, however moving forward I intend to try and make the videos a little more interactive and informative for those that wish to follow along in my build. This is the first plane I've build and have so far learned a ton, with plenty more mistakes to go, I'm sure!
https://youtu.be/gCuZJMsxl1Q
Sean A.
RV-8 -- N8SA
Builder #83674
Empennage -- In Progress
Old 01-29-2019, 05:07 PM
MIKE JG MIKE JG is offline
Subscribed to this thread. I can't tell you how useful it is to have someone in the same general part of a build that is documenting their work via video.
Thank you!
-Mike G
Northeast Ohio
RV-8
Working on the HS
Builder #83203
VAF Dues Paid Monthly
My Build Log: https://eaabuilderslog.org/?blproject&proj=7YG4STHvs
Old 02-04-2019, 08:06 PM
Default RV-8 Rudder Update
Just posted my latest video of my RV-8 Aircraft build! watch, like and subscribe for future videos! This video and forward rather than just the time lapse I actually explain a little more what the process is that I'm doing so it is easier to follow along. Enjoy!
https://youtu.be/T497ERMPGj4
Sean A.
RV-8 -- N8SA
Builder #83674
Old 02-14-2019, 06:42 PM
Default Build Video
Latest installment of the build is up on YouTube!
https://youtu.be/xIX8fFLt_G4
Sean A.
RV-8 -- N8SA
Builder #83674
Old 02-15-2019, 11:11 AM
Thanks for the video, definitely agree that's the way to go with the repetitive stuff sped up like that.
Makes it easy to follow along.
-Mike G
Northeast Ohio
RV-8
Working on the HS
Builder #83203
Old 03-01-2019, 08:57 AM
Default Rudder sub structure pre assembly
Latest update of my Rudder build pre assembled and match drilled the entire sub structure and skin as well as deburring and dimpling.
https://youtu.be/CXZIvcNzQDc
Sean A.
RV-8 -- N8SA
Builder #83674
Old 07-11-2019, 05:01 PM
Default Priming Video
Latest update to the build (video is a few months behind the actual process, more videos to follow.) But I decided to video the process and methods I use with the Stewart Systems to clean, etch and prime my interior parts. I will also include this video in the primer section.
https://youtu.be/rgjXVCwV3V8
Sean A.
RV-8 -- N8SA
Builder #83674
Old 12-17-2020, 10:49 PM
Default Finally back in the shop!
Been away from the build for far too long, but here's the latest, preparing the Right Elevator sub-assembly, I also made a mistake on the counterbalance assembly that I explain and show what I did to remedy it the second time around...
https://youtu.be/NgcWs12-b98
Sean A.
RV-8 -- N8SA
Builder #83674
Old 01-07-2021, 10:06 PM
Default Right Elevator Video Up
New Video up assembling the Right Elevator, pretty straight forward, just lots of rivets! (200 in this video) Left Elevator videos should be out soon-ish, just falling behind on the editing hope you enjoy!
https://youtu.be/Du7VUvXJS1I
Sean A.
RV-8 -- N8SA
Builder #83674
Old 01-15-2021, 07:55 PM
Default Left Elevator work
Left elevator sub assembly work...almost done with the empennage!
https://youtu.be/7ooFFlWjWv8
Sean A.
RV-8 -- N8SA
Builder #83674
