Go Back   VAF Forums > Model Specific > RV-14
Old 01-23-2019, 01:42 PM
mcblinn mcblinn is offline
Default Help for a TALL pilot
Good afternoon. This is my first post.... I'm very interested in the rv-14, but I have a problem. I'm 6'6'' with a 35'' inseam. Half the people I talk to say no problem, the other half say no way. Would love to be able to "try one on". I'm in central Florida. At the very least, I would like your opinions. Thanks in advance.
Old 01-23-2019, 01:50 PM
MarkW's Avatar
MarkW MarkW is offline
Welcome Michael,
We have a few RV's @ KSFB and a few building but I do not know of a RV-14 local. Hopefully someone will reach out.
I am 6'5 w/ 36" inseam and I built my RV-9 to fit me. I have no issues. Seems like a RV-14 would be even better height wise and mostly width wise.
Mark
RV9 - N14MW - Flying
G3X - ECI Titan I0-320
Catto three blade prop
http://www.mykitlog.com/MarkW
Old 01-23-2019, 01:53 PM
ty1295 ty1295 is offline
I am 6'4", 32 -34 inseam with an RV9a I built with almost 14 mod, rudder pedals moved forward and have plenty of room. The RV14 will not be an issue.
Jeff Scott
RV9A First Flight 9/30/19
Old 01-23-2019, 01:56 PM
mulde35d's Avatar
mulde35d mulde35d is offline
Default Tall
Micheal, I am 6?3 and 200 lbs with a 99th percentile sitting height. Small aircraft have always been an issue with my head hitting the canopy. I got the opportunity to sit in an RV7/8/10/ and 14. The 7 was too short in either seat (head pressed into the canopy). The 8 was good in the front seat but impossible in the rear seat. The 10 was ok, but with the headset on it was occasionally touching the cieling. In the 14 I had no contact between by head and the canopy except in low G maneuvers, but that was likely due to the loose seatbelt. Not saying you will be the same, but hopefully this helps.
Jon
http://www.mykitlog.com/mulde35d
RV-14A Sold
RV-10 Empennage - Searching
Wing - On Order
Old 01-23-2019, 04:13 PM
Discus2b Discus2b is offline
Mentioning inseam means you are more concern about leg room than head.
I am 6?3?, tall in the torso. I sit on 4? of Medium dense foam that compresses down to 2?, 3? of back foam, Bose headset, geezer accordion sun shade above head. All this leaves me with about 1? between headset and shade.
I wear 31? inseam pants and thinking of bring the pedals 1? closer. Plenty of leg
room available.
I say 6?6? should be no issue.
R
Old 01-23-2019, 05:20 PM
Rotorheadrob's Avatar
Rotorheadrob Rotorheadrob is offline
Hey Tall Guy,,, I?m tall too,
,,,added this bar to recline my seat (-8A) and it?s helped a lot. Also, using a thin high density foam seat cousion with an Air Hawk air cousion on top of that-just right 👍🏼. I?m 6?3? and on the larger side. The -8A fits great.
Vansaircraft.com
TALL SEATBACK OPT.
WD-823-PC
Dues Paid
SK-64, S-70i & RV-8A
Old 01-23-2019, 05:36 PM
Glen P Glen P is online now
TALL SEATBACK OPT.
WD-823-PC
Hi Rob,
Could you tell me more about this Van's option? Is it along the lines of the almost a -14 mod?
Glen Palmer
Toronto, Ontario
Working on -7 avionics/wiring
Dues paid July 2021
Old 01-23-2019, 06:03 PM
dschlicht dschlicht is offline
Default Tall pilot
Michael
I’m am building an RV-14 and wondered the same thing. I flew in a local RV-14A and had no issues with leg or head room. I’m 6’-6” 36” inseam and weigh 250#. You should have no trouble at all.
Dave
RV-14
Builder #140456
N814PW reserved
Old 01-23-2019, 06:12 PM
Pilotjkl Pilotjkl is offline
I?m 6?4? 210lbs 36? in seam, I fly a -6 with almost a -14 mod, I fit quite well.
Commercial pilot
A&P
RV-6 0-320 160hp
Cessna 170A
King Air B200 Blackhawk conversion
2019 dues paid
Old 01-23-2019, 06:50 PM
Thx for all the quick replies. Very helpful
