Old 12-18-2018, 11:56 PM
Aero_Octaveus Aero_Octaveus is offline
Default Bulkhead Recess F-601K-1fitment
Has anyone had issues with the fitment of the Bulkhead Recess F-601K-1.
When I cleco mine onto the bulkhead, the top most #30 holes each side (and the one lower down #40 holes) do not want to align. The recess width seems to be 1/8" narrow overall. Is it possible that maybe Van's didn't get the bend 100% perfect on this one?
If I force the cleco's then the corners really "dog ear" up and there is considerable stress on those corners.
Garet Hess - Edmonton, AB
RV-7A - Emp and Wings Done. Working on fuse
2020 Donation Current
http://garetsrv.blogspot.ca/
Old 12-19-2018, 08:11 AM
Raymo's Avatar
Raymo Raymo is offline
I don't recall any issues with the fitment on my firewall recess during installation a couple years ago.
Those holes aren't that far off. I suspect they'll be fine as you drill them up to size. Some opt for monel rivets here too.
Ray
RV-7A - Slider - N495KL - First flt 27 Jan 17
O-360-A4M w/ AFP FM-150 FI, Dual PMags, Vetterman Trombone Exh, SkyTech starter, BandC Alt (PP failed after 226 hrs)
Catto 3 blade NLE, FlightLines Interior, James cowl, plenum & intake, Anti-Splat -14 seat mod and nose gear support
All lines by TSFlightLines (aka Hoser)
Old 12-19-2018, 08:21 AM
rv7charlie rv7charlie is offline
It wouldn't be too surprising. IIRC, mine was a little weird when trying to get all the various 'flaps' to end up in the right places. But the firewall is non-structural; especially that recess. If I couldn't get all the holes to line up perfectly by tweaking the bends, I'd just 'match drill' the recess ear to match the existing hole in the firewall/aluminum angle (which *is* structural) with everything lying flat.
But that's just me; call Van's if you can't get comfortable with it.
Charlie
Old 12-19-2018, 08:34 AM
So sometimes a person just has to laugh at themselves. A good sleep and a fresh perspective is all that was needed. Can you spot what I did wrong? The key word being firewall "recess", not firewall "protrusion"
Old 12-19-2018, 08:58 AM
Flying Canuck Flying Canuck is offline
I found that this recess was the one part of the firewall that wasn't worth fussing over much before I was ready for firewall forward and the top front skin. There are a bunch of the rivet holes that will get drilled open for a bolt (might be screws too) and extra holes for platenuts. There may be some penetrations through the recess for control cables for your installation (not in the plans, but commonly done). Also, the access through that hole is very useful for as long as you can keep it open. It makes it much easier to mount items to the middle area of the front of the firewall.
Of course you will need to rivet that in place before hanging your engine and you can't completely seal it up until you've got your cables through. It gets a little tight.
One thing I did was fashion an insert for that recess that I used for a pivot for my fuselage rotisserie. That worked quite well up until the time that I was done with having to rotate the fuselage.
Claude Pitre
RV-9A #91081, C-GCPT
Dynon SkyView HDX, IO-320 and WW 200RV C/S. Flying as of August 6, 2018
Added GPS 175 and authorized for IFR April 1, 2021
Interactive map of all of my flights here
Old 12-19-2018, 09:36 AM
Awesome, excellent advice Flying Canuck. I didn't think to read that far ahead to see how the firewall penetrations in that particular area are going to play out.
I'll rest easy on this one.
Old 12-19-2018, 03:07 PM
longranger's Avatar
Now there are at least two members of that club...
I seem to remember I had to fight with it regardless of orientation.
Miles (VAF# 1238, Paid up as of 12/20)
RV-7 TU 904KM (reserved)
Construction Log
Empennage Album, Wings Album, Fuselage Album
