Old 12-03-2018, 08:28 AM
bkervaski's Avatar
bkervaski bkervaski is offline
Default What Phase I Looks Like
Here is what Phase I looks like on a Garmin G3X ... just in case anyone was wondering
Now if I can just figure out how to clear the tracks so I can see the map again
RV-14A #140376
N196 (Flying)
2019 Bronze Lindy
Old 12-03-2018, 09:10 AM
SmilingJack's Avatar
Menu, Menu, Track Log, Menu, Clear Active Track.
Garmin changed it sometime ago. It keeps getting me too
John Mastro
RV-8 (SOLD)
10 years of Awesomeness!
Old 12-03-2018, 03:41 PM
airguy's Avatar
airguy airguy is offline
I was expecting to see an airplane with the cowling and access plates removed and tools all over the wing, because what MY Phase I looked like!
Garden City, TX VAF 2021 dues paid
N16GN flying 900 hrs and counting; IO360, SDS, WWRV200, Dynon HDX, IFD440, G5
Old 12-04-2018, 02:50 AM
Don E Don E is offline
Default Can?t see any oil leaks!
Bill, that?s too funny!!! Mine is looking similar but with different place names. Only 14 hours in, too. Darn weather...
Old 12-04-2018, 08:59 AM
Flying Canuck Flying Canuck is offline
Mine looks similar, kind of like a homework assignment from a Remedial Circle Coloring class. This is what 3090 NM, 224 gal of 100LL, 24 flights, 65 landings, 100 days and a 25 NM radius limit looks like.
Claude Pitre
RV-9A #91081, C-GCPT
Dynon SkyView HDX, IO-320 and WW 200RV C/S. Flying as of August 6, 2018
Added GPS 175 and authorized for IFR April 1, 2021
Interactive map of all of my flights here
Old 12-04-2018, 10:35 AM
airguy's Avatar
25nm radius, wow. I asked for and got a 50 x 75 nm chunk of airspace, but I'm also out here in west Texas and that chunk of airspace contained exactly 1 controlled field.
Old 12-04-2018, 11:45 AM
Canada's rules are simply a 25NM radius from the airport you're based in. I don't have any controlled fields in mine, my base has 24hr advisory services but isn't technically controlled. We also have a requirement for a flight plan (or itinerary) for any flight more than 25 NM from departure airport, so the radius on the test area makes it so we don't have to file any flight plans.
Claude Pitre
Old 12-04-2018, 04:52 PM
Paul K Paul K is offline
Looks like a good argument for a shorter test period of you are just turning circles to burn required time! If on the other hand you are actually performing flight test in those circles......
Paul K
West Michigan
2021 donation made, exempt but worth every dime!
Old 12-04-2018, 05:29 PM
Definitely some time burning there. Some serious testing as well. Probably the biggest deliverable in the testing was the figuring out the throttle, prop and mixture settings for the various stages of flight and the resulting air speeds, climb and glide rates, fuel burn and CHTs. The time burning provided a great opportunity for that, and the auto pilot made for some nice patterns.
Claude Pitre
Old 12-04-2018, 08:38 PM
Not waisted time but I had about 15 hrs to fly off after I finished all my test cards and wished I could have gone someplace else just for some different runways to play with!
Paul K
West Michigan
