Old 11-05-2018, 07:09 AM
Nova RV Nova RV is offline
Default CHT numbers in the 14
For the guys already flying, are any of you having high CHT issues? Yesterday was about 59 degrees OAT and I never saw CHT numbers over 300, mostly mid-high 200s (all cylinders pretty consistently close). I'm not complaining but my tech helpers who both have 7s and high CHT issues thought I must have some reading errors to be that low and I don't recall anyone with a 14 posting about high CHT issues. I was flying close to WOT and full rich as these were the first flights. Can I solicit some real world CHT numbers from you guys please?
Chris Moon
Leesburg, VA
CFI-I ASMEL, ATP
RV-14A kit # 140243 (flying as of 11/18)
www.mykitlog.com/chrismoon/
Old 11-05-2018, 04:10 PM
Don E Don E is offline
Default Just started flying
Chris, OAT was 64 degrees F when i flew last Thursday and i saw CHTs in the 350s on 3&4, and 370s on 1&2. Running hard to seat valves, leaned to 12gph at 78% power. I?m at six hours and consistently seeing temps in the 300s.
Old 11-05-2018, 04:49 PM
Bavafa Bavafa is offline
What temp do you guys get for the oil, if I understand it correctly, IO390 runs cooler on CHT but hotter on oil temp.
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - SOLD
N258SM RV14A - IO390EXP119 - in progress
Dues paid
Old 11-05-2018, 05:49 PM
gen1313 gen1313 is offline
I consistently get mid to high 180's in the cruise for oil. That doesn't seem to change much regardless of OAT. In the climb oil temp does get up to 210 sometimes but I try to avoid that. The worst scenario for oil temps is in the circuit on hot days. CHT's are never a problem.
Graham Haley
RV-14 #140181
Flying 5th January 2017
230+hours now
Old 11-05-2018, 06:29 PM
n982sx n982sx is offline
This is my experience, mostly 300 and below in cruise. In the summer on a hot day I can get as high as 350-375 during climb, but then they come down to below 325.
I have to watch the oil temps on climb in the summer. Not really a problem but in the summer, cruise oil temps between 200 and 210 are normal for me. As the ambient air during the winter gets colder my oil temps in cruise come down into the 180's.
Bob Meyers
Built and Flying RV-14A N626KM SN 140093 http://n626km.com
Built and Flying Sonex N982SX http://n982sx.com
Last edited by n982sx : 11-05-2018 at 06:45 PM. Reason: Refined my off the top of my head numbers after reviewing actual data.
Old 11-05-2018, 07:51 PM
Default Oil temps
My oil temps during the first six hours of break in have been in the 185-200 range. I have not done any sustained climbs, just 3,000 feet, then running hard. Touched 200 degrees at 78% power with 64F OAT.
Old 11-05-2018, 08:12 PM
KeithB's Avatar
KeithB KeithB is offline
Similar results to others - cruise CHTs are around 300 (couple under, couple just over). At higher altitudes (OATs 30-50), all are 280-290. On high power climbs I might hit 350 - have never seen a 400 temp ever. On a cross country winter flight with -5?F OAT, CHTs fell to 200 and I had to run rich of peak to get temps up.
Oil temps run higher as mentioned - similar results with 200-210? in high power settings, but 220? is the highest I?ve seen. One nice side benefit is the engine really warms up fast after start. Unless it?s winter, I never need to warm up - 100? oil after a short taxi.
Keith Brown
RV-14A Builder - kit #136 (complete) and #770 (in process)
N314KC - First flight Mar 8, 2017, 24th in the air, >750 hrs
XP-400 Aero Sport Power, replaced with Lyc Thunderbolt 390
RV-6A sold
Sport Pilot (weight-shift control) - Airborne XT912
Dues paid 9/2021
Old 11-06-2018, 06:41 AM
Thanks guys, I will get some more data and post it tomorrow. Plesase keep sharing anyone who is currently flying. This would be important info for the next guys getting ready to fly as far as what temps seem correct for the 14
Chris Moon
Leesburg, VA
CFI-I ASMEL, ATP
Old 11-06-2018, 06:45 AM
BCP Boys's Avatar
BCP Boys BCP Boys is offline
Default Seat those valves
Chris, I would consider leaning out a bit to get things hotter on a new engine to seat those valves properly.
Amir
RV-7 - Regretfully Sold
RV-10 - Sold
Supporting VAF since the first visit
Old 11-06-2018, 06:46 AM
Jesse's Avatar
Jesse Jesse is offline
I flew with a guy in his RV-14 in Michigan. His CHT?s got over 300 in the climb, maybe as high as 350 on one or two, but in cruise at least one or two were under 300. I couldn?t believe it.
In an RV-7A with a 390 that just started flying, the highest CHT I?ve seen is 394, and Cruise is around 350. Oil temp stays above 200 until the descent. I?ve seen as high as 214.
Jesse Saint
