Old 11-01-2018, 10:46 AM
subpar_bucker subpar_bucker is offline
Default Question about forward end of fuel line F-12127A in Section 27iS page 7
Is anyone else having trouble aligning the tube with the bypass fitting assembly? I realized after cutting and flaring that I did not bend the tubing forward of the bulkhead in order to align it squarely with the bypass fitting
Here's a picture that (hopefully) illustrates the issue. I haven't tried posting a picture prior so apologies if this doesn't work. I can get the nut to reach its mating portion of the bypass fitting but it just doesn't want to thread. I wasn't very aggressive with the amount of force I applied - looking for advice on whether this should go together or if I need to redo this line.
Here's the link to the picture if the image embed isn't working: https://photos.app.goo.gl/EpGh7PEXFyFF8Xkd7
Old 11-01-2018, 01:59 PM
Crafting N112DR's Avatar
Crafting N112DR Crafting N112DR is offline
Default elbow grease
I would try a little elbow grease to get it to align correctly. It's okay to slightly put a bent here, see my photo for alignment.
___________
David Rohrlick
PPSEL, A&P
N112DR (RV-12iS) (SOLD)
Airworthiness signed off by the FAA 1/23/2020
First Flight on 3/14/2020
Phase I Finished on 5/7/2020
Serial#12-0864
https://youtube.com/c/CraftingN112DR
VAF donation made for 2021
Old 11-01-2018, 05:51 PM
That worked like a charm. Thanks for the suggestion!
Old 01-05-2020, 12:39 AM
Rob H Rob H is offline
I?m lost as to how you guys got that fuel line fitted through there without bending the **** out of it. Especially after the instructions have you make the 89 degree bend and flare at the aft end. I?ve tried fishing it through from the back and also through the access hole in the belly skin below the tank. It looks like I need to put the 89 degree bend in last if possible. I may need to call Van?s. There?s got to be an easier way that I?m not seeing.
RV12 - building
Empennage finished
Wings finished
iS Fuselage in progress
ULS Fuselage kit - SOLD
Farmer - corn & soybeans
Firefighter
Knoxville, IL
