Old 10-31-2018, 08:09 AM
romanov's Avatar
romanov romanov is offline
Question Damaged dimple on a skin, is it fatal?
Hi Guys ,
I need your educated opinion here, we damaged a
dimpled holes a bit, what do you think is it so
bad that requires a new skin?
here is what happened:
We just started to scuff the VS skin (VS-801PP)
as a preparation for priming / coating.
Accidentaly we applied too much force on the inner side where dimpled cone is.
As a result there are a few dimpled holes that are a bit larger now: (about 0.15mm) and they are a bit flatened , you can see the results on pictures attached. Also
have to add here that the front side of the holes is
completely fine.
Please advise if it may cause a problem or may affect the structure strenght.
The big question now is , whether we can continue with that skin or we have to order a new one.
Looking forward for your recommendations.
check that album for illustration:
https://imgur.com/a/Oes7Ocq
Blogging my RV14 here:
https://bit.ly/2PzjPzS
Old 10-31-2018, 08:18 AM
bkervaski's Avatar
bkervaski bkervaski is offline
The general rule is that you can adjust a dimpled hole one time, either reversing it (if you dimpled the wrong direction) or re-dimpling. After that, the aluminum is considered fatigued and needs to be replaced.
I would try to dimple them again first, but just once. If that doesn't fix it for you the best solution is to just get another part and consider that one practice .. I had lots of "practice"
RV-14A #140376
N196 (Flying)
2019 Bronze Lindy
Old 10-31-2018, 08:29 AM
iwannarv iwannarv is offline
Vans is the final say, but these aren't 'reverse dimpled'. I'd say touch them up with dimple dies again and let the rivet do its job, maybe upsize one length rivet.
EDIT: The heavy mechanical scuffing method may lead to more issues and would change my recommendation.
Brad Brensing
RV-10 Emp/Tailcone - Complete, QB Wings - Complete, Fuse - Building, Finish Kit - May '21
Never judge a man by his trim tabs.
Old 10-31-2018, 08:47 AM
Mel's Avatar
Mel Mel is offline
Personally I would go to 1/8" rivets in these holes. You are using way too much scuffing force. Very little scuffing is needed, especially if you are using a self-etching primer.
Mel Asberry, DAR since the last century. Over 1,000 certifications accomplished. Discount for Veterans, Law Enforcement, Fire Fighters.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 10-31-2018, 08:52 AM
romanov's Avatar
Question
Thanks guys, the mail to Vans been
sent. Your ideas are very interesting.
How often people go to 1/8 rivet
while killing 3/32 holes?
Old 10-31-2018, 09:44 AM
wirejock's Avatar
wirejock wirejock is offline
Default Process
Consider changing the process. Scuff before dimpling.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Donated 12/01/2021, plus a little extra.
RV-7A #73391, N511RV reserved (3,000+ hours)
Empennage, wings, fuse, finishing kit done. Working FWF
Disclaimer
Old 10-31-2018, 10:00 AM
Brantel's Avatar
Brantel Brantel is offline
How the heck did you scuff the skin hard enough to both flatten a dimple and enlarge a hole? How is this even possible? What are you using to scuff ?
Brantel (Brian Chesteen),
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 10-31-2018, 10:05 AM
ppilotmike's Avatar
Default Oops Rivets..
..have the same head as an AN-3 but the shank of an AN-4. However, if this condition is over a whole lot of holes, I'd start again, since you've hardly begun.
Mike Rettig
VAF Dues Current
RV-10 - Working on engine / prop installation
rocketman1988 rocketman1988 is offline
Default ...and
And remember, if you need to go up a shank size, you can use "Oops" rivets. They have the same sized hand as the specified rivet but the shank is one size larger...
Bob
Aerospace Engineer '88
RV-10
N464RL
Dues+ Paid 2020,...Thanks DR+
Old 10-31-2018, 10:09 AM
romanov's Avatar
That one. Wont do it again.
https://imgur.com/6j97R5H
