Erimo
Hello,
I'm in the process of configuration my G3X Touch system (2 GDU460). I have some issues including flaps working.
As the RV14 Van's manual indicate it, the flaps positioning sensor (pos 12) is behind the flaps motor shaft. It wired to GEA 24 and the motor to GAD 27.
When I calibrated the flaps, I create 4 positions from 0 to 32 (numbers of degrees from flat position to full position) with two intermediate positions : 10 and 20. There are two switches (panel and left stick) which work well in manual mode (configuration mode).
When the G3X Touch pass in normal mode, it is impossible to move the flaps normally. They move full down (the motor donesn't stop to run) and the up position switch is inoperative on both switches.
I didn't find any information in the G3X manual about this troubleshooting.
Have you an idea ?
I read a post about this kind of issue and tried to calibrate the pos-12 close to the limits but the result is the same. I'm desperate !![Confused :confused: :confused:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
![Frown :( :(](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Regards.
Have you an idea ?
Regards.
