titanhank
I installed the almost rv14 seat mod in my rv6 tip up, but instead of using a second lock bar, I used a teleflex cable. It locks up tight and works perfect. Flight tested to Vne with no canopy movement at all. The biggest hurdle was the initial taking a sawsall to your airplane. The room gained was unbelievable. If you have been considering the seat mod, i would highly recommend it.
Hank
Hank
