Old 06-25-2018, 09:36 PM
Torch76 Torch76 is offline
Default Rivet Gun Slipped
This was my first time riveting close up against another piece of aluminum. The gun slipped, and these smileys occurred.
1. Is this a situation where I feather out the smileys with a Scotch Brite pad so they don't catch my nail, add some primer over the scuffed area, and move on?
2. Any tips for riveting with the gun in close proximity to another piece? It's hard to feel like I have solidly placed the gun and bucking bar.
John
RV-8 Emp
Old 06-25-2018, 09:44 PM
Carl Froehlich's Avatar
Carl Froehlich Carl Froehlich is offline
Three ways:
- Use a longer set. This allows for a decreased angle
- Use an offset set.
- Use at least three layers of masking tape on the set. This is the rule for all round heads to never have a smiley again.
Carl
Last edited by rv7boy : 06-26-2018 at 02:13 PM. Reason: Changed "offest" to "offset"
Old 06-25-2018, 09:56 PM
DaveO DaveO is offline
It happens to the best of us. Build on
Dave
RV-7A N1243A Sold
Old 06-25-2018, 10:52 PM
terrye terrye is offline
1. I always push hard on the rivet gun just before pulling the trigger. On my gun there's an internal spring I can feel when I push on the gun.
2. I use snap-soc rivet set caps, for me these work better than masking tape
https://www.browntool.com/Listview/t...a/Default.aspx
3. Squeeze the trigger gently when first starting the gun, but the trigger should be fully open after the first couple of hits.
4. Use only enough air pressure to drive the rivet in about one second. More and it's hard to control the gun and easy for it to bounce off the rivet.
5. Use a tungsten bucking bar.
Terry Edwards
RV-9A (Fuselage)
2021/2022 VAF Contribution Sent
Old 06-25-2018, 11:45 PM
6. Make it a point to hold forward pressure on the gun for one full second after you release the trigger.
Old 06-26-2018, 09:01 AM
airguy's Avatar
airguy airguy is offline
7. Until you gain proficiency in riveting (and maybe even after), use the rivet gun in short bursts of 1/2 second or less and then evaluate the rivet and hit it again. I still use this technique with flush rivets to prevent the rivet gun "walking" and giving smileys.
Garden City, TX VAF 2021 dues paid
N16GN flying 900 hrs and counting; IO360, SDS, WWRV200, Dynon HDX, IFD440, G5
Old 06-26-2018, 09:30 AM
wirejock's Avatar
wirejock wirejock is offline
Default Gorilla tape
All good advise. Smiles don't look too bad. Rub them with Scotch Brite to remove the stress riser.
I use Black Gorilla Tape on the rivet. A square is good for several rivets and if you slip it covers the adjacent area. Just make sure the set is squarely on the rivet. It will leave a smidge of adhesive behind. Scrape it off with a fingernail.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Donated 12/01/2021, plus a little extra.
RV-7A #73391, N511RV reserved (3,000+ hours)
Empennage, wings, fuse, finishing kit done. Working FWF
Disclaimer
Old 06-26-2018, 10:50 AM
Consider whether you should reduce the pressure for those rivets. Maybe, maybe not. Try it on a test sample and see.
Dave
Old 06-26-2018, 01:49 PM
StressedOut StressedOut is offline
You don't want to leave those marks because cracks will eventually form. They look deep enough that a ScotchBright pad probably won't be enough, unless you really need an arm and shoulder endurance workout. A blend out repair is usually done for this kind of damage. I use 220 grit to start, then either 400 or higher grit for a final sand. Take care not to remove too much thickness. Measure it after you finish. If you've removed 20% of the thickness you're getting into unknown territory.
When you do the repair you'll be removing the clad layer entirely. You need to touch up the bare aluminum with at the very least some Alodine (Bonderite) 1201. Just brush it on undiluted and rinse per the instructions. This stuff is itself corrosive to aluminum if not rinsed properly. You may want to drill out that rivet so the parts are separated if you use Alodine to insure you don't get it in the faying surface that can't be properly rinsed. As an alternative you can prime as you mentioned. Either way is acceptable.
You can safely ignore the smiley on the rivet head (assuming you don't drill it out for the Alodine). Section 5, page 5-05 says "Rivet OK but looks bad".
Good luck!
Art Jackson
RV-14A Kit#140433
Completed: Vertical Stab/Horizontal Stab
Scrapped: Rudder
Working on: Empennage (Elevator, Rudder #2, Aft Fuselage)
Ordered: Wing Kit (Arrives March 2021)
Construction log - mykitlog.com/ajackson
Dues paid on March 2021
Member of EAA Chapter 92 (KCNO)
Pet peeve: "Lose" (rhymes with "booze") is the opposite of "find". "Loose" (rhymes with "juice") means "not tight".
Old 06-26-2018, 02:20 PM
jcarne's Avatar
jcarne jcarne is offline
I almost always do this, it avoids a lot of mistakes. I also make sure to keep pressure until a second after letting go. The end of riveting is almost always where problems arise.
One thing no one has mentioned yet is my biggest personal rule, do everything possible to squeeze a rivet before shooting one, especially AN470 rivets. I keep a thin nose yolk, 1.5", 3", 4", and the all mighty longeron yolk for my two different squeezers. Many people will argue that if you develop good shooting skills you won't need to squeeze as often; to each their own but squeezing rivets almost never goes wrong.
Jereme Carne
PPL
RV-7A Flying as of 03/2021
Exempt but gladly paying!
