Go Back   VAF Forums > Model Specific > RV-6/6A
Old 06-14-2018, 02:47 PM
boulderick boulderick is offline
Default Do I need to relocate my oil cooler?
Recently bought an RV-6A that flew first in 1995. Now that it is getting hot in Colorado, I'm having trouble with high oil temperatures. We're going through the steps I've seen in other forum posts - checking the baffles for leaks (there are some places to tighten up), checking the oil cooler for flow (expensive to have it cleaned, but we may do that), checking the oil temp sender and gauge and doing a compression test (tomorrow after work). The one thing that seems odd about this aircraft is the position of the oil cooler. It's just inside the left hand intake, mounted horizontally with a piece of 5/8" aluminum angle behind it to help direct some of the airflow through the cooler. Seems that airflow would largely bypass the cooler mounted this way. Has anyone seen this kind of configuration? Do I need to change it to the more traditional firewall mounting with a SCAT hose from the back of the engine baffles?https://www.dropbox.com/s/9fxjxqhw5a..._0225.JPG?dl=0
https://www.dropbox.com/s/pw4xzolppw..._0226.JPG?dl=0
Old 06-14-2018, 03:28 PM
Ironflight's Avatar
VAF Moderator / Line Boy
This was a very common location for the oil cooler on early RV’s - I have seen it there on all fo the very early -6’s I have seen. We relocated teh one on Louise’s -6 to the rear of the baffles when we did a new baffle kit, and I think we gained a little cooling. If you are having temperature problems, moving it might get you a little bit of relief.
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 06-14-2018, 03:54 PM
RONSIM's Avatar
RONSIM RONSIM is offline
Default Same location, no problem with temps in FL
I do not have that angle, on mine. --- I have O360 FI, CS, and have never had temp issue, even at the 95+temp/195%+ humidity ().
Ron
RV-10 Co-built, maintained, flown (sold)
RV-8A Maintained and flown (Sold)
RV-6A (Sold) Bought and Flying (N177RV), upgrades $$$
IO360, 180HP/CS, AFS 5600T, D10A, G650, G430, G327, ADS-B, VIZ385 AP
Very Happy Contributor
Comm, SMEL, CFII, A&P
Based at KCLW (Clearwater, FL)
Old 06-14-2018, 04:53 PM
dlloyd3's Avatar
dlloyd3 dlloyd3 is offline
Side view pic you can see daylight above the cooler, below the baffle. Air going around your cooler does no good. Make it go through your cooler.
Dave
M20C
Old 06-14-2018, 04:59 PM
DanH's Avatar
DanH DanH is offline
And where are the seals on the baffle wall behind the spinner?
Dan Horton
RV-8 SS
Barrett IO-390
Old 06-14-2018, 05:12 PM
Ron
I was wondering about that angle and planned on experimenting with taking it off, putting a curved piece there to direct the air flow down, etc and seeing if that has any effect on cooling.
Old 06-14-2018, 05:14 PM
Thanks. I wasn't looking for air escaping around the cooler. Good catch. I'll seal that up and see if it makes a difference.
Old 06-14-2018, 05:21 PM
Good question. I'm looking at images for RV engine baffles and most don't have seals behind the spinner. Makes sense to add these as I can imagine air escaping through the dead zone right behind the spinner if there is nothing there to stop it. Seems I may be losing quite a lot of cooling air that better seals will improve.
Old 06-14-2018, 05:24 PM
Ron
Ron, do you have the 7-row Vans cooler, a larger cooler, or a high efficiency cooler? After I seal up the air leaks the best I can, if I still have heat issues, I'm thinking of replacing the original 7-row model with a high efficiency part.
Old 06-14-2018, 05:49 PM
jpowell13 jpowell13 is offline
Default Mine is there too
Mine is in the same location. My engine came out of a Musketeer with the original baffling which I adapted and used in my plane. The inlet ramp on factory planes tends to be much more vertical with the cooler facing the ram air more directly than with the 6A, so I fabricated a simple scoop over the oil cooler to catch more air. I think it works well. An added bonus is that it moves the weight of the cooler forward. John
