Go Back   VAF Forums > Main > Safety
Old 06-05-2018, 08:28 AM
9GT's Avatar
9GT 9GT is offline
Default Plane Ownership & Complacency
I see this often since I spend so much time now at the airport hanger working on my -9A. (KGDW is a very nice rural airport but has little activity) I see so many pilots who own their own planes do a VERY limited pre-flight inspection, if they even bother to do one at all! Last weekend on Sunday took the cake for me. I could not believe what I had witnessed. The owner drove in, opened his hanger, pulled out his plane, (not an EXP), closed his hanger up, hopped in, started his engine and immediately began to taxi. He did not even bother to use the taxi-way. Cut across the grass to the runway and just took off. No pre-flight inspection, no run-up or mag check,,,,nothing! Not even a radio call! About an hour later an incoming plane announces his position and intentions and advises their is a second incoming plane with inoperative radio, his buddy who took off earlier. I think a lot of people who own their own planes feel since they are the only ones flying the plane, they know it well enough to get away with this type of stuff. Wrong!
David C.
Howell, MI
"Donor Exempt" but donated through Dec. 2021
Old 06-05-2018, 08:44 AM
zampano zampano is offline
I saw something similar at a flight club a month ago. Was doing my flight review at a local flight training center and the chief instructor said that "they fill the planes with fuel every night and hangar them, so nobody ever sumps the tanks during a preflight". He also implied that if I wanted to do it, I had to bring my own equipment.
Old 06-05-2018, 09:15 AM
Mel's Avatar
Mel Mel is offline
Default So they TEACH complacency!
I would be inclined to find another instructor!
Mel Asberry, DAR since the last century. Over 1,000 certifications accomplished. Discount for Veterans, Law Enforcement, Fire Fighters.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 06-05-2018, 11:00 AM
cgroves cgroves is offline
That would pretty much end any working relationship with that instructor and the flight right there.
Old 06-05-2018, 11:03 AM
precession precession is offline
What I find most interesting about this kind of stuff is the group-think psychology at work. It seems like people often see someone else doing something, so they think "well I guess it must be okay," and start following suit. The story about the flight instructor saying there's no need to sump the tanks because the aircraft were in the hangar overnight and that's how we do it here, is amazing.
I think in flying it's good to try to learn what's generally prescribed as safe and why, and after that you need to have a resistant, independent streak that causes you to resist the urge to follow what someone else might be doing unless you reach your own, independent conclusion it's safe.
I was at a fairly active uncontrolled field, with a flight club and flight instruction going on. It seemed like most people coming into the field pretty much did the usual pattern entries you'd expect (downwind, crosswind, upwind). Then one of the guys in the club starting doing straight in approaches as a matter of routine. Now I realize they are legal, and you especially see them being done by commercial operations who are on a schedule and flying larger, high fuel-burning aircraft, and maybe by guys flying IFR approaches. However, IMO they are not really preferred or a good idea from a safety standpoint if not justified for some reason, particularly for people who are just on VFR pleasure flights with no real time constraints in small aircraft that don't burn much fuel.
I could have sworn that after that more and more people around the field were doing straight in approaches and it was becoming more common. Finally, one of the more senior guys who wasn't part of the club, and happened to be entering the pattern when this guy was doing one of his straight-in approaches, openly took the guy to task on the ground after landing, saying "we don't do straight in approaches here."
Obviously, he had no real right to dictate what another pilot could or couldn't do provided his behavior was within the law, but I thought it was good. We're fortunate to still have aviation regulations that provide us with some latitude and discretion. But that being the case, I think the need is there to speak out when appropriate and use social pressures to try to get people to conform with what's safe for everyone. Social influences can work both ways.
RV-4 in NJ
Old 06-05-2018, 07:54 PM
asw20c asw20c is offline
Many times before a planned flight I will come out to the airport the evening before when I have no deadlines and no reason to rush so I can take my time to do a thorough preflight. Perhaps that's what this gentleman did as well.
Empennage Complete
Wings Complete
Fuselage Complete
Waiting on Finishing Kit
Old 06-05-2018, 08:47 PM
N941WR's Avatar
N941WR N941WR is offline
You should always check the tank quantity, sump the tanks. And check the oil before a flight in the morning, even if a preflight is performed the night before.
Water can separate from even 100LL or condense in the tanks. Someone could get into your hangar and syphon your fuel, or worse. (I once had someone drain some fuel from my plane at a lunch stop.)
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 06-05-2018, 09:04 PM
AX-O's Avatar
AX-O AX-O is offline
i should probably stop doing everything the day/night before a trip. Would not want anyone thinking i am not following the ?rules?.
Just because you did not witness something, it does not mean it did not happen.
These type of post don't add value to this community. If you are that bothered by what you saw, please go speak to that person.
Let us keep this positive and mininize the assumptions.
Axel
RV-4 fastback thread and Pics
VAF 2020 paid VAF 704
The information that I post is just that; information and my own personal experiences. You need to weigh out the pros and cons and make up your own mind/decisions. The pictures posted may not show the final stage or configuration. Build at your own risk. Further more, these are my opinions and not those of my employer.
Old 06-05-2018, 10:27 PM
9GT's Avatar
9GT 9GT is offline
There is no assumption here. I know what saw. The value to the community here is remind fellow aviators to NOT get complacent with their aircraft. The very least someone should do is sump the tanks and do a mag check. In my book, a pre-flight the day before a flight does not carry over to the next day. I put that in the same catagory of "progressive condition inspections".
David C.
Howell, MI
Old 06-06-2018, 06:42 AM
olyolson's Avatar
olyolson olyolson is offline
Default Preflight
I agree with both Axel and David. Let's not jump the gun and criticize unless we know all the facts but if someone wants to act like an idiot who am I to stop them, "whatever melts your butter".... There are a lot of stupid people in the world, just don't be one of them.
On the other hand, probably not a good idea to get complacent and just jump in and go. These are not cars & we can't pull over to to the side of the road if we have an issue. I am the only one that flys my RV-4, it is kept in a single locked hangar and I know no one has touched it since the day before. But like most of you (or probably all) I do a thorough preflight every flight. One time I was working on the airplane, got it all back together, put all the tools away (or so I thought) and went home for the night. The next day I drove out to the hangar to go fly and guess what I found on the back seat? A small hammer and a set of pliers I used to gently tap the hinge pin back into the hinge that holds the back seat frame to the floor. Who knows what kind of damage they would have done to the canopy or the back of my head or worse.
Like Axel, I like to get the airplane ready the day before if I can but that doesn't mean you just "kick the tires, light the fires, brief on Gaurd, first one in the air is the leader".
Don't be too quick to judge but let's be smart out there........
RV-8, Aerosport IO-360M1B, MT 3 blade, AFS 5500
RV grin every flight
"Sure is nice to have smart friends"
