Old 05-09-2018, 02:15 PM
hesty hesty is offline
Default Another RV-7A takes its first flight!
https://www.dropbox.com/s/c5shc1jagz..._4942.JPG?dl=0
https://www.dropbox.com/s/xnmthbd064..._9366.JPG?dl=0
https://www.dropbox.com/s/xgolqdr2rn..._9368.JPG?dl=0
https://www.dropbox.com/s/irxblzv5g3..._9373.JPG?dl=0
https://www.dropbox.com/s/vnivpf5edb..._9414.JPG?dl=0
VAF Community,
After 7.5 years my "QB" RV-7A finally got airborne last week and I already have 10 hours on her. A great moment and I was able to share it with a builder friend who came with though the FAA Qualified Pilot program. I am concentrating almost entirely on the proper engine break-in/seating of rings. I have a few questions for the VAF guys in the know. As I have close to 10 hrs, I am expecting the rings to seat very soon and CHT's to drop. I am wondering what kind of drop I should see. As I am doing the phase one unfortunately a little too late for ideal cool temps in the Las Vegas area. Oil consumption seems somewhat minimal, buy higher than I would expect if the rings had already seated. The highest I've seen is about 418 for a couple min on the initial climb. It's a new stock lycoming IO360-M1B engine. MT CS prop. Wheel pants are not installed. Nose leg/pant is complete and can be installed, but the mains are not completed yet. Below are some cruise reference numbers to help build a picture...
4500 ft, 7170 ft DA, WOT, 2400RPM, OAT 82F, oil temp 184, 130 IAS kts
CHT's: 388,391,373,391
4500 ft, 7130 ft DA, WOT, 2500RPM, OAT 82F, Oil temp 186, 132 IAS kts
CHT's: 392, 397, 375, 382
4500 ft, 7160 ft DA, WOT, 2450RPM, OAT 83F, Oil temp 184, 131 IAS kts
CHT's: 388, 394, 372, 389
My biggest question is when should I expect the seating to occur? Will it be sudden? What kind of drop in CHT's should I see?
If the temp drop is not significant, I think I will need to make cowling adjustments to lower the CHT's so the plane is useful in warm weather.
Thanks for any insight and input. I have read a bit on VAF about the break-in process, but have not seen what to expect.
Chad Hesterman
N11ZH
Boulder City, NV
Chad Hesterman
Boulder City, NV
working on wrapping things up before Airport move. RV-7A slider.
Lycoming IO360 engine and MT 3-blade.
(2016 =VAF= Donation made)
Old 05-09-2018, 02:23 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Default Congratulations
Chad------big Congrats on the new fledgling
Photos ------ aint official until the photos, ya know..........
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 05-09-2018, 03:49 PM
CHAD====congrats my friend on a major milestone!!
Tom
Ridgeland, SC
Old 05-09-2018, 04:09 PM
unqualified unfluencer
Congratulations Chad!!!! Looking forward to more flying posts down the road.
v/r,dr
Doug Reeves (your host)
Old 05-09-2018, 05:11 PM
PilotjohnS PilotjohnS is offline
Default Congrats
Congrats. Now that I am building this means more to me than when I was a lurker.
John S
WARNING! Information presented in this post is my opinion. All users of info have sole responsibility for determining accuracy or suitability for their use.
Dues paid 2020, worth every penny
RV9A- Status:
Tail 98% done
Wings 98% done
Fuselage Kit 98% done
Finishing Kit 35% canopy done for now
Electrical 5% in work
Firewall Forward 5% in work
www.pilotjohnsrv9.blogspot.com
Old 05-09-2018, 05:23 PM
Installing your wheel pants will make a noticeable improvement in your CHT's.
My experience with break in was there was no step change in CHT's.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 05-09-2018, 05:58 PM
jrs14855 jrs14855 is offline
Default CHT
Think of two separate scenarios for CHT. Before the rings seat and after the rings seat.
Before the rings seat every effort should be made to keep the CHT below 400, a momentary excursion to 425 is unlikely to glaze the cylinders.
After the rings are seated longer periods at or just below 425 are unlikely to hurt anything.
I have a lot of experience with Pitts Aircraft, parallel and angle valve 0 360 and parallel valve 540.I don't recall ever flying a Pitts with a CHT gage. Those engines likely saw a lot of CHT time at or near the red line. Never a problem.
I had to break in my 0 320 in 110-120 temps in July in Havasu. On the climb if the CHT started past 400 I pulled the power back and leveled off.
I never did see a significant CHT drop in cruise, just in climb. Never burned any oil from hour number one.
Old 05-09-2018, 08:48 PM
jcarne's Avatar
jcarne jcarne is offline
Congrats good sir!
Jereme Carne
PPL
RV-7A Emp. done
Wings done
Fuselage done
Finish kit almost done
Exempt but gladly paying!
Old 05-10-2018, 06:46 AM
Raymo's Avatar
Raymo Raymo is offline
What Kyle B. said. The landing gear creates a LOT of drag that the engine must overcome with power/heat. Once the fairings are installed, you'll see 15-20 Kts faster cruise and can climb faster at the same power settings so you'll have more cooling air over the engine.
Mine did the same thing. Go ahead and install the nose gear fairings and you should see some improvement. If you have P-Mags, retard their timing a few degrees until the mains are installed.
Ray
RV-7A - Slider - N495KL - First flt 27 Jan 17
O-360-A4M w/ AFP FM-150 FI, Dual PMags, Vetterman Trombone Exh, SkyTech starter, BandC Alt (PP failed after 226 hrs)
Catto 3 blade NLE, FlightLines Interior, James cowl, plenum & intake, Anti-Splat -14 seat mod and nose gear support
All lines by TSFlightLines (aka Hoser)
