Old 05-05-2018, 05:08 PM
Carl Froehlich's Avatar
Carl Froehlich Carl Froehlich is offline
Default Forward top skin tip
I fitted the top skin before cutting out the panel for the baggage door. While fitting I took the left over angle from rolling the lower fusleage skin to make a couple of hold bars between the firewall and the next aft bulkhead. This holds everything aligned for baggage door and cowl fitup.
Carl
Old 05-05-2018, 08:25 PM
wjb's Avatar
wjb wjb is offline
Good idea!
Bill Bencze
N430WB RV-7 @KHAF, Flying 100+ hrs
VAF 2021 donation happily made
Old 05-07-2018, 02:57 PM
cdeerinck's Avatar
cdeerinck cdeerinck is offline
Default No Prime?
Out of curiosity, why does your door say "No Prime" on it?
~Chuck
DG-800S Sailplane
QB RV-8 -- Working on final wiring and the engine
84CX Reserved
