Old 04-30-2018, 08:01 PM
Larry DeCamp Larry DeCamp is offline
Default Garmin pin crimper question ?
Just got my LRU components for G3x suite. I am not familiar with the little connector pins. What crimper tool do I need to complete this suite install with highly reliable results ?
Larry DeCamp
RV-4 fastback in process w/ Superior roller 360/AFP/G3X/CPI/Catto3b
Clinton, IN
Old 04-30-2018, 08:07 PM
krwalsh krwalsh is offline
Default Steinair
You can get an inexpensive crumpet for those fromSteinair:
https://www.steinair.com/product/4-way-indent-crimper/
Or buy the DMC AFM8:
https://www.steinair.com/product/dan...m8-m225202-01/
The AFM8 can be found on eBay for less money. Buy the positioners from Stein.
Kevin R. Walsh
Cozy Mk-IV
Old 04-30-2018, 08:22 PM
Nova RV Nova RV is offline
The G3X has both standard density and a lot of high density pins too so you need the high density insert as well for the crimper from Stein. Works great.
Chris Moon
Leesburg, VA
CFI-I ASMEL, ATP
RV-14A kit # 140243 (flying as of 11/18)
www.mykitlog.com/chrismoon/
Old 04-30-2018, 08:52 PM
Pat Hatch's Avatar
Pat Hatch Pat Hatch is offline
Larry,
I think you would be better off getting the Daniels AFM8 on eBay with the three positioners that you need (K41, K42 and K13-1). A target price would be around $100 for the crimper. You'll need the AFM8 for the high density pins anyway, so you might as well get it and its positioner for the standard density pins, the K13-1. If you were just dealing with the standard density pins, the $38 crimper from Stein would suffice, but the majority of your crimping will be the high density pins. There are no high density sockets, but you might want to crimp some on to short segments of 22AWG wire for testing continuity at some point in the project. If you are troubleshooting for continuity it's handy to be able to insert a wire/socket on to the pins in the connectors for your ohmmeter testing.
If you're really on a budget, you can get by with the $38 crimper with a $10 positioner for the high denisty pins on Stein's web site.
Pat Hatch
RV-4 (Gone to RV heaven)
RV-6 (N44PH - Flying)
RV-7 (Sold)
RV-8 (Builder & Avionics Installer)
www.phaviation.com Trim Relay Boards/Flap Actuators
www.pathatch.com/blog (Photography)
Track Me
Old 04-30-2018, 08:57 PM
g3xpert's Avatar
g3xpert g3xpert is offline
Post
Hello Larry,
As others have said, you should have good results with either the low cost crimper that SteinAir sells or from a new or used Daniels AFM-8 crimper.
If you decide to go with the Daniels AFM-8 crimper, you only need the K13-1 (standard density male/female pins) and K42 (high density male pins) positioners.
You can precisely crimp every pin in an entire G3X Touch system with GNS/GTN navigator with these 3 items.
Steve
Garmin G3X Support
g3xpert@garmin.com
1-866-854-8433 - 7 to 7 Central Time M to F
Please email us for support instead of using Private Messaging due to the limitations of the latter.
pilot2512 pilot2512 is offline
The best price I found for the positioners is directly from Daniels Manufacturing.
Jay
RV-9A
Empennage complete.
Wings complete.
Fuselage in progress
Wiring in progress
2020 Donation made!
Old 04-30-2018, 09:16 PM
Mark33's Avatar
Mark33 Mark33 is offline
Default AF8
How about the AF8 with the TH-163 Turret? I know it?s really for large AWG (12-24), but I think it would come in really handy in other areas of the build.
Old 04-30-2018, 09:27 PM
wjb's Avatar
wjb wjb is offline
As mentioned above, the AFM8 is perfect for all the low-current/signal wiring.
However, I used a number of Deutsch connector for high power connections, and found that the big boy AF8 with turret was perfect for the DT and DTM sized machined contacts.
Bill Bencze
N430WB RV-7 @KHAF, Flying 100+ hrs
VAF 2022 donation happily made
Old 04-30-2018, 09:32 PM
Mark33's Avatar
My thoughts exactly!
Old 04-30-2018, 11:22 PM
jliltd's Avatar
jliltd jliltd is offline
I will try an analogy here. Using the cheap pin crimper kind of works okay. It's like using a Harbor Freight air hammer to drive rivets. Using the Daniels AFM8 is like using a fine-tuned Sioux rivet gun with a feathering trigger to drive rivets. So you have zero doubt about the quality of the crimp with the Daniels. Just like the good feel of the Sioux. It's a zen-like thing. The size of the AFM8 mini tool is perfect. The larger turret crimpers can be unwieldy (I have both). As for the mentioned Deutsche connectors. I use the cheaper tool kits available on eBay for those and save my Daniels for actual avionics work. I really like Deutsche connectors, by the way.
Life is short. Get the right tools and get great results while still saving money over ordering custom harnesses. Feel the zen. Lots of fun too.
Jim
Jim Ivey
RV-8
(and a few more airplanes)
