Go Back   VAF Forums > Education > Probable Cause Documents Discussed
Old 04-24-2018, 07:58 AM
Sam Buchanan's Avatar
been here awhile
Default Final Report; 2016 RV-4 fatal accident
https://app.ntsb.gov/pdfgenerator/Re...=HTML&IType=FA
Sam Buchanan
RV-6
Old 04-24-2018, 08:37 AM
Johnnybgoode Johnnybgoode is offline
Default What can you say?
Life is too short to fly impaired. Not surprising, if this is indeed a contributing factor.
P.B.
Privileged to explore the world in the venerable Lockheed C-130 and the regions around NC in a work-in-progress RV-4, kit #2614, while paying the bills aboard an Airbus A-330.
Old 04-24-2018, 08:38 AM
pierre smith's Avatar
Default Yep
Thanks Sam. I've often warned pilots about powerlines and rivers. Sad.
Best,
Rv10 Sold
46 years ag pilot/CFI
Air Tractor 502/PT-6
Building RV-12, Wings, fuse, emp complete. FWF in progress.
Old 04-24-2018, 09:54 AM
airguy's Avatar
airguy airguy is offline
Toxicology testing performed by the FAA Bioaeronautical Research Sciences Laboratory, Oklahoma City, Oklahoma, for the pilot was negative for carbon monoxide and cyanide. The testing identified ethanol at 0.059 gm% in urine, 0.037 gm% in muscle, 0.036 gm% in brain, and 0.033 gm% in blood (unknown source). In addition, 10.1 ng/ml of tetrahydrocannabinol (THC, the primary psychoactive substance in marijuana) and 13.1 ng/ml of 11-carboxytetrahydrocannabinol (THC-COOH) was identified in blood. THC- COOH was also identified in urine.
Ethanol is the intoxicant commonly found in beer, wine, and liquor. It acts as a central nervous system depressant. The effects of ethanol on aviators are generally well understood; it significantly impairs pilots' performance, even at very low levels. Title 14 CFR section 91.17 (a) prohibits any person from acting or attempting to act as a crewmember of a civil aircraft while having 0.040 gm/dl or more ethanol in the blood. Because ingested alcohol is distributed throughout the body, levels from different post mortem tissues are usually similar. Ethanol may also be produced in body tissues by microbial activity after death.
Marijuana is a psychoactive drug with therapeutic levels as low as 0.001 ug/ml. According to NHTSA's Drugs and Human Performance Fact Sheets, "It is difficult to establish a relationship between a person's THC blood or plasma concentration and performance impairing effects. Concentrations of parent drug and metabolite are very dependent on pattern of use as well as dose. THC concentrations typically peak during the act of smoking, while peak 11-OH THC concentrations occur approximately 9-23 minutes after the start of smoking. Concentrations of both analytes decline rapidly and are often < 0.005 ug/mL at 3 hours." A detailed report of the toxicological results is included in the public docket associated with the investigation.
Just the facts, do the math and draw your own conclusions.
Garden City, TX VAF 2021 dues paid
N16GN flying 900 hrs and counting; IO360, SDS, WWRV200, Dynon HDX, IFD440, G5
Old 04-24-2018, 10:32 AM
rvator51's Avatar
rvator51 rvator51 is offline
As someone who has lost a friend to a powerline, altitude is your friend.
Regards,
Thomas Velvick
Goodyear, AZ (KGYR)
2020 Donation sent.
N53KT RV-6a finished 2018, Flying
N7053L RV-4 Wife's RV
N56KT RV-4 Finishing
Old 04-24-2018, 01:14 PM
A half-inch line is invisible in flight, and nearly invisible even when standing still unless you're able to get just the right contrast/background/lighting conditions. There's no hope of "see and avoid" tactics helping you avoid a line of this size while flying.
Old 04-24-2018, 10:19 PM
Schooner69 Schooner69 is offline
NEVER low fly in an area you have not previously recce'd. Even that caution is useless unless you can guarantee that nothing has been erected/strung since your recce...
I know of three people killed and two aircraft destroyed after encountering a wire because of spur-of-the-moment low flying.
Old 04-24-2018, 11:19 PM
BobTurner BobTurner is online now
g.
Yep. Some years back a Mooney crashed, fatally, in the Altamont pass east of KLVK. Scud running in the dark. They hit a high tension line that had been installed while they were away.
Old 04-25-2018, 03:48 PM
moosepileit moosepileit is offline
They hit a Zipline cable, right? Powerlines at least may give you chart depictions and towers to see. A zipline in the trees gives neither.
RV-6, bought from builder.
O-320, slider, carb, mags, FP
Old 05-12-2018, 01:51 AM
dlomheim dlomheim is offline
Default Common Killers
Yeah, too many passengers have been killed shortly after a pilot says: "Hey, watch this..."; and if the pilot is on drugs, all fear may be gone which further increases the likelihood of a bad outcome!
Doug
RV-9A FWF
RV-3A restored / sold
