Old 03-30-2018, 03:01 PM
SgtZim SgtZim is offline
Default flywheel to hub alignment
Hi, basic question here. Does the 0 on the flywheel match to the (smeared) 0 on the hub?
RV-8 slow build
IO360-M1B Sensenich fixed pitch
Garmin G3X
GTN 625
GNC 255
GTR 20
GTX 45R
G5 x 2
Facebook "log" https://www.facebook.com/BZsRVproject/
Old 03-30-2018, 03:06 PM
Jesse's Avatar
Jesse Jesse is offline
Yes it does.
Jesse Saint
Old 03-30-2018, 03:10 PM
Thanks! Kind of makes sense but I'm not an A or P (yet)
RV-8 slow build
Garmin G3X
GTN 625
GNC 255
GTR 20
GTX 45R
G5 x 2
Old 03-30-2018, 04:56 PM
pazmanyflyer's Avatar
pazmanyflyer pazmanyflyer is offline
Aren't the some of the holes and studs different sizes also for proper fit / alignment? For some reason I have it in the back of my head they were.
Carlos in Arizona
EAA Chapter 538 www.chapters.eaa.org/eaa538
Wittman Tailwind W8 N53CH (built & sold)
Pazmany PL-1 N2029 (bought & sold)
RV7 - N537TC (reserved & building)
Emp, Wings & Fuse done - working on FWF
"The air is an extremely dangerous, jealous and exacting mistress. Once under the spell most lovers are faithful to the end, which is not always old age." - Winston Churchill
Old 03-30-2018, 06:02 PM
Jesse's Avatar
Some props have different recesses for the prop flange, but the ring gear will fit any way.
Jesse Saint
Old 03-30-2018, 06:32 PM
Russ McCutcheon's Avatar
Russ McCutcheon Russ McCutcheon is offline
That's odd, I had my ring gear/flywheel marked for many years so I would always return it to the correct position and recently checked and it will only fit in one position, it will not fit down over the one prop thread insert in the 0 position if the flywheel is in the wrong position, and the prop will only go on in two locations 180 degrees so you can't get that wrong either. I bet you find more than one arrangement out there though.
Russ McCutcheon
@rv4welder on Facebook
russmccutcheon@gmail.com
We build many of your RV weldments.
Old 03-30-2018, 06:56 PM
Ironflight's Avatar
VAF Moderator / Line Boy
I have unfortunatley seen flywheels that would go on in any direction - not supposed to, but they did. So I am always suspicious now - put #1 at TDC and check the timing mark on teh back of the flywheel to make sure its in teh right spot when installling a new-to-me flywheel on an engine. It doesn?t;t take long to verify that you?ve got it right.
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 03-30-2018, 07:53 PM
az_gila's Avatar
az_gila az_gila is offline
Exclamation
It may depend on how far the individual prop drive bushings stick out in your particular configuration.
Looking at the Lycoming SI for the bushings the index bushing fits a hole in the crank that is about .031" larger than the other 5.
http://www.yeeles.com/Lycoming_Refer...ns/SI1098G.pdf
I know that on both of my O-360's ( -A4K and -A1A) the flywheel will only fit when the "O" marks line up.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 03-31-2018, 10:15 AM
Toobuilder's Avatar
If that was true, then the timing marks would be wrong more often than right. There "should" be a single drive lug with a slightly larger shoulder diameter that indexes with a single appropriately sized hole in the ring carier. The ring carier "should" only go on one way - and should do so easily by hand. That said, it's a close enough fit that you can smoke it down with the prop bolts, but if misindexed you essentially guarantee a cracked ring carier.
Michael Robinson
______________
Harmon Rocket II -SDS EFI
RV-8 - SDS CPI
1940 Taylorcraft BL-65
1984 L39C
Old 03-31-2018, 10:58 AM
lr172 lr172 is online now
This wouldn't surprise me. A lazy or inattentive mechanic could replace the index bushing (the one with the larger OD) with one of the non-index bushings. This would allow the flywheel to be installed in any configuration. I would suggest confirming any flywheel installation on an engine new to you.
Larry
