Old 03-08-2018, 09:47 AM
ronschreck's Avatar
ronschreck ronschreck is offline
Thumbs up Hoses with integrated fire sleeves from TS Flightlines
Check out the hoses that my friend Tom Swearengen of TS Flightlines sent me. I am busy installing my overhauled IO-360 engine after 2150 hours of trouble free service. Tom offers these hoses with "integrated fire sleeves" which give the hoses a great look with a surface that is smooth and easy to keep clean. I sent Tom all of my old hoses and he matched them for a perfect fit. Thanks, Tom for great service and a super product! (I have no connection to TS Flightlines other than knowing Tom personally and appreciating the fine work that he does.)
(PS: I'm overhauling the engine because the plane is down to replace a cracked canopy and I prefer to overhaul the engine now rather than wait for some failure to mandate an overhaul in the middle of the contest flying season. Now I'm good, hopefully for another 2150 hours of flying. )
Ron Schreck
IAC National Judge
RV-8, "Miss Izzy", 2250 Hours- Sold
My Aerobatic Video
My Formation Video
CAF B-25 - Airbase Arizona
VAF 2022 Donor
Old 03-08-2018, 04:08 PM
RV8Squaz's Avatar
RV8Squaz RV8Squaz is offline
They are a thing of beauty!
Jerry Esquenazi
RV-8 N84JE
Old 03-08-2018, 04:58 PM
Toobuilder's Avatar
A timely post as I'm just about ready to install "flight" hoses on the Rocket and I was hoping that Tom offered the integrated product. He'll be getting an order from me soon.
Michael Robinson
______________
Harmon Rocket II -SDS EFI
RV-8 - SDS CPI
1940 Taylorcraft BL-65
1984 L39C
Old 03-08-2018, 06:40 PM
For those interested, we use Stratoflex 124J and 101 hose for our integral firesleeved assemblies with the appropriate hose cuffs. The 'experimental' versions use our stainless hose ends, the 'certified' versions use Stratoflex certified hose ends. Yes, we can do custom creations.
Tom
RV7A Tail Kit Completed, Fuse started-Pay as I go Plan, on hold while we develop new products for RV builders
Ridgeland, SC
Old 03-09-2018, 07:03 AM
jseavolt's Avatar
jseavolt jseavolt is offline
+1 I used Tom's lines throughout my plane. I have only high praise for the man and his work!
Jason "Bacon" Seavolt
RV8 N143MS "Fiona"
6.5 yr build
1st flight 4/23/17
Painted 11/17/17: Tribute to F16 Arctic Aggressor (Eielson AFB, AK)
-Over 200 hours VFR/IFR flown during 1st 15 months
-Bronze Lindy OSH18 (still in shock)
Old 03-09-2018, 07:15 AM
Walt's Avatar
Walt Walt is offline
I've replaced many hoses for customers over the years, all from Tom. He makes a quality product, is a great guy with unmatched service, I highly recommend TS Flightlines for all your hose needs!
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
RV7A built 2004, 2000+ hrs, New Titan IO-370, Bendix Mags
Old 03-09-2018, 11:09 AM
bkthomps bkthomps is offline
so are you making these in-house or are you just ordering to spec? I have traditionally ordered these from aeroquip to spec and am curious if any alternatives exist (mostly due to cost!)
Old 03-09-2018, 11:17 AM
RandyAB RandyAB is offline
I'm sure impressed with Tom's continued support and patience as well as his terrific product.
______________________
Randy P.
1st time builder
RV10 - QB wings and fuse. Working on cabin top
St. Albert, Alberta, Canada
Reserved:C-GRPY
Old 03-09-2018, 12:23 PM
Raymo's Avatar
Raymo Raymo is offline
Tom and Steve make all the lines in-house.
Ray
RV-7A - Slider - N495KL - First flt 27 Jan 17
O-360-A4M w/ AFP FM-150 FI, Dual PMags, Vetterman Trombone Exh, SkyTech starter, BandC Alt (PP failed after 226 hrs)
Catto 3 blade NLE, FlightLines Interior, James cowl, plenum & intake, Anti-Splat -14 seat mod and nose gear support
All lines by TSFlightLines (aka Hoser)
Old 03-09-2018, 01:47 PM
One point not made here is that these hoses with integral fire sleeve are considerably smaller in outside diameter than comparable locally-fabricated hoses made with Aeroquip 303 cloth/rubber line and fittings. They also are more flexible. Ultimately they make for easier routing and more space in that tight working space between firewall and the engine.
BTW I've never done business with Tom but have on more than one occasion received helpful advice from him (once totally unsolicited). Based solely on his willingness to reach out and help a person who isn't even a paying customer, one has to believe he's a pretty decent character with whom to do business.
The lines on our aircraft were made by Steve. He went way over the top in accommodating our needs. From everything I have read here it seems Tom and Steve are a good match in their customer service ethic.
