I was trying to use Cherry-max (I have access to quite a few) to hold the Ribs to the Spar Web. They worked but were difficult and much more picky about being perpendicular to the surface. As you may know most rivet guns need to be modified just to do the job anyway.
I tried the LP4's that came with my kit, and found them easier to install and felt that they had more of a pull-up than the Cherry-max. For this application I do feel that there would be nothing gained by using other than what the plans call for.
Sure there are other places I just couldn't bring myself to use the commercial rivets
and went with cherry-max, like the aileron skins at the joint line and the counterbalance. I spent the extra bucks and went with the CR3222's they have a corrosion resistant stem and aircraft aluminum body. They also are self plugging. I don't want stuff collecting in the little holes on the exterior starting corrosion later and looking ugly, open rivet centers on the exterior are ugly.
Anyway after a few ribs with cherry-max, I was glad I switched to the LP rivets for the rest of them.
Have fun and.......
