Old 01-26-2018, 04:54 PM
Sam Buchanan's Avatar
Sam Buchanan Sam Buchanan is online now
been here awhile
Default Custom-built wood tailwheel lift
There was a good thread recently about how to raise the tailwheel for maintennce and the formerly available Tail-Mate was part of the discussion. I fully intended to fabricate a copy of the steel Tail-Mate but decided to first whip together a wood version out of scraps in the shop. I moved it to the hangar today and made its first flight and the thing works incredible well.
Why didn't I do this twenty years ago??
A couple of notes:
The eye-bolt inserted into a hole in the ramp is a 'safety' in case the winch slips. There is also a 3/8" bolt that is inserted through the dolly that secures the tailwheel after it is rolled onto the dolly. The winch is the cheapest boat trailer winch I could find on that huge auction site.
Sam Buchanan
RV-6
Old 01-26-2018, 05:08 PM
DanH's Avatar
DanH DanH is offline
Sam, you're a genius. And a liar. "Just whipped it together from scraps"....yeah, sure buddy, we believe you
Dan Horton
RV-8 SS
Barrett IO-390
Old 01-26-2018, 05:53 PM
Jimd Jimd is offline
Sam,
Can we plan on plans, or at least a few dimensions? Im not in a hurry, so if you want a bit more time for phase I that might be okay.
Looks good to me, thanks for the pictures!
Jim
RV-6
RV-10 tail kit 50%
(When do I get to measure something?)
"Flying north of the Arctic Circle and back - several thousand dollars,
Doing it in an RV you built yourself - PRICELESS!"
Old 01-26-2018, 06:00 PM
terrye terrye is offline
What, no primer?!?
Seriously, nice design. Looks good.
Terry Edwards
RV-9A (Fuselage)
2021/2022 VAF Contribution Sent
Old 01-26-2018, 06:12 PM
been here awhile
Originally Posted by Jimd View Post
Sam,
Jim
Jim, I see a couple of areas that you can improve with your build. If the lower end of the ramp 2x4 is extended a bit farther from the rear upright (increased angle) you will have more clearance from the rudder. Also, while looking at the photos I wonder why I didn't put a bolt at the base of the rear upright to tie everything together a bit more than just the drywall screws. I'll probably remove the center screw in that group of five and put a bolt in its place. Yes, over engineering, but....why not.
Total height is ~40" which is more than enough to bring the longerons of the RV-6 past level. The dolly slide is merely wood-on-wood and works very smoothly with no lube/wax needed. There are 3/16" spacers under the dolly sides to prevent it from pinching the ramp.
No primer or sikaflex was needed...guess you could consider this thing a 'slider'....
Hope this helps.
Sam Buchanan
RV-6
Old 01-26-2018, 06:38 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
SWEEEET
Looks like front page material to me.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 01-26-2018, 08:22 PM
Very nice work, Sam. I'm saving a PDF of this page so that I can make one when I'm farther along.
Dave
Old 01-26-2018, 08:43 PM
tdk tdk is offline
Default Me too!
Finished mine a few nights ago. As usual, mine is overbuilt. More like a medieval siege engine.
Tom Kocher
Columbia, MD
RV-7 N616TK
Flying!
Old 01-26-2018, 09:48 PM
SJordan SJordan is offline
Amazing work guys, but if anyone wants to take the easy way out I use this motorcycle lift to lift the back of my -4 and to put the lower cowl on by myself with a 3-blade Catto.
https://m.ebay.com/itm/New-300lb-Mot...MAAOSwLnlWoILd
Shawn Jordan
KDVT
RV4. N11XZ
2018 dues paid.
Old 01-26-2018, 10:08 PM
alpinelakespilot2000 alpinelakespilot2000 is offline
Another home made wood version post #5 in this thread:
http://www.vansairforce.com/communit...il+lift+harbor
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2022
