Old 01-17-2018, 04:36 PM
azflyer21 azflyer21 is offline
Default Rudder Leading Edge Started
Today I set up my bench to roll the Rudder leading edge. I successfully finished 2 sections, now that I'm comfortable with the process I should be able to finish the rest tomorrow.
Kevin Lippert
RV-14A N1402 Flying 03-2020
Phase 1 Complete 07-12-2020
YouTube Channel
Build Log
Zenith 750 completed 2016 -
Sold
Old 01-17-2018, 09:03 PM
Eztroller Eztroller is offline
Looks good. I read your blog and had the same issues using the tape on the trailing edge.
Old 01-18-2018, 07:57 AM
Did you do anything to close the gap in the Trailing Edge? I talked to Van's and they said it will not affect flight performance, but it will bother me knowing I have a few gaps.
Kevin Lippert
YouTube Channel
Build Log
Sold
Old 01-18-2018, 12:41 PM
goatflieg's Avatar
goatflieg goatflieg is offline
I had a very similar setup on my work table for rolling. It works very well.
Martin J Filiatrault
Clarkston, MI
RV-8 #83507 - registered; final assembly continues; engine remounted.
Builder websites:
http://goatflieg.blogspot.com/
http://www.mykitlog.com/goatflieg/
YouTube Channel:
https://www.youtube.com/user/goatflieg
Dues paid for 2022... extra payment included for psychological therapeutic services rendered.
_______________________
Have you ever gotten the feeling you were smarter than you could ever prove?
Old 03-31-2018, 06:49 PM
Bernard Hartnell Bernard Hartnell is offline
Thumbs up Flush rivets
Besides several attempts at reforming the leading edge of the elevator; I noticed my nemesis were a few ill placed round head rivets inside the aft of horizontal stab. So I drilled them out, countersunk and installed flush pull rivets. Problem solved!👍
Plans may now have been revised to correct the close tolerances.🤷🏼*♂️
