Go Back   VAF Forums > Education > Instrument Flight Rules
Old 12-25-2017, 10:55 PM
DakotaHawk's Avatar
Default IFR training in an RV-7? I did it!
I completed my RV-7 in 2009 and have over 1100 hours on it to date. Living in the Seattle area, there are a lot of weather issues to deal with. In the past few years, there have been a few times that I?ve had to cancel planned trips due to weather. I?ve also had to turn back from coming over the Cascades due to getting stuck VFR on top of the clouds. It?s never fun at the end of a trip to come home and spend the last hour of the flight looking for a hole in the clouds to circle down through. It?s not very safe either!
https://www.dropbox.com/s/p9mfwnwabswhh5b/1005.JPG?dl=0
So last year I decided it was time to move forward on my Instrument ticket. My goal was to use my own plane to train in, so the first hurdle was to put in an instrument panel that would be legal, and would be easy to fly on instruments. I wasn?t interested in the basic six-pack with vacuum gauges and a VOR. No! I wanted to have something that I would be comfortable with.
Oshkosh is a great place to look at the latest and greatest. I spent an entire week with one thought running through my head ? IFR Instrument Panel! By the end of the week, I had decided on my setup and began planning the new panel. The legacy Dynon EFIS and EMS would go away. The Garmin transponder and comm radio are out also.
My new panel has Dynon Skyview 10? Touch and Dynon Skyview 7? EFIS, Avidyne IFD440 Nav/Com/GPS, PS Engineering audio panel, Dynon Comm, Dynon (Trig) Transponder, Dynon autopilot, and meets the 2020 ADSB requirements. I cut the new panel and had a friend do the graphics and silkscreen work for me. The old equipment was removed, and new equipment installed.
https://www.dropbox.com/s/5cgxs2treo...%2036.jpg?dl=0
I spent a few months testing the new equipment, learning how to use the Avidyne, and looking for any bugs. I found a couple of minor issues that were easy to clear up. The worst issue though, was the Nav radio (IFD 440 Nav). Although the glideslope on an ILS approach was rock steady, the localizer needle was very erratic. It took a lot of troubleshooting to figure this one out, but I finally narrowed it down to one of the BNC ends on a short coax from the Nav/GS splitter to the Avidyne radio. And sure enough, when I examined the BNC ends, I found one pin had not been fully inserted in the assembly. Here?s a video of what the localizer looked like with the bad BNC pin, and a picture of the bad BNC pin next to a good BNC connector.
https://youtu.be/wTDYREBJ_3A
https://www.dropbox.com/s/awgdzp4hu4...%2041.jpg?dl=0
With everything working correctly, it was time to begin IFR training. I wasn?t interested in going to one of the local schools, renting a G1000 Cessna 172, and spending thousands of dollars to learn a system that I would never use again. I wanted to train in my RV-7, so I had to find an instructor who would be willing to fly with me. Seattle has a great flying community, and I was able to find several CFIIs who could do the job. After flying with several CFIIs, I settled down to three instructors who would team-teach me.
I was concerned about the ability of the RV-7 as an Instrument platform. Would it be too twitchy? Too nimble? There?s a reason why so many people get their Instrument ticket in a Cessna. It?s just a good, stable, reliable airplane. I have done a lot of aerobatics, formation flight, cross country, and sight-seeing in my RV-7. Now it was time to see if it could survive in the Instrument training world.
https://www.dropbox.com/s/18rn7p0bg9...%2055.jpg?dl=0
We began training with standard maneuvers ? except the standard maneuvers were done with my foggles on! And the RV-7 behaved? OK. Not perfect, but not bad! I had to learn to have a very smooth, light touch on the stick, and really focus on the gauges. It took a few hours of maneuvers to get my skills up to par. Holding altitude, heading, and speed isn?t easy at first, but eventually I figured it out.
Approaches, Holds, and course intercepts turned out to be extremely easy with the equipment I had installed. One of my instructors said that flying with my panel felt like cheating, because the instrument scan all happens on one instrument, the auto-pilot can fly straight and level (or a heading and altitude) while I was trying to plan the next maneuver. We moved onto the Cross-country flight relatively quickly, with a flight from Renton (KRNT) to Hillsboro (KHIO) to Astoria (KAST) to Hoquiem (KHQM) to Renton (KRNT). Along the way, we did an ILS approach to full stop, a Localizer to full stop, a VOR to the missed approach, and an RNAV-GPS/circle to land. The cross-country was done in about 75% IMC conditions, and my RV-7 performed wonderfully!
https://www.dropbox.com/s/5wffnh5gws...%2042.jpg?dl=0
Fast forward a few months, I had racked up a whopping 41.0 hrs of actual/simulated IMC, and it was time to take my checkride. Once again, I had to find a DPE who would be willing to do an Instrument checkride in an RV-7. Sure enough, I found my victim. I briefed him on my equipment, the experimental RV-7, the tailwheel, the panel, etc. Oddly enough, he still agreed to go along for the ride! Because of the experimental nature of the plane, as well as the engine, as well as the panel, I had to be prepared to answer all questions about airworthiness! We spent about 45 minutes going over airframe and engine logs, discussing the work and logbook entries that I could do as the builder, and then going over ADs and service bulletins for the plane, engine, propeller, and equipment. Finally, he declared that my RV-7 may indeed be airworthy, and we completed the checkride.
https://www.dropbox.com/s/c32b5eynsa...%2013.jpg?dl=0
In summary, if you feel like you?ve got a good handle on flying your RV, if you are very comfortable with the instrumentation on your panel, and if you don?t want to go back to a Cessna for your Instrument ticket, there?s really no reason for you not to use your RV!
Good luck!
Scott "Grumpy" Stewart
RV-14 N144P (First Flight on Apr 17, 2021)
Arlington, WA
Old 12-26-2017, 06:54 AM
Tooch Tooch is offline
Default Me Too
Thanks for your post and congrats. I too am learning instruments in my RV-7A. I have 400 hours flying it and found that the maneuvers were not as bad as some said they would be. I also didn't want to learn in an other plane. I did do some research first and found an examiner who would do my check ride in my plane. I am about half way through the flying part and studying for my knowledge test.
I find the knowledge part way harder than the flying. Learning all the stuff i will never use is a drag. I'm 55 now and been vfr flying since 1992. It is a little harder to learn when your older but I also have a lot of cross country experience so that helps. This is definitely making me a better pilot. I hope to be able to post a successful check ride in the spring.
Old 12-26-2017, 08:14 AM
Northernliving Northernliving is offline
Nice write up, and thanks for the inspiration! It's on my list!
Brian J.
Boston, MA
RV8 Based at ORH - Purchased
RV8 - The Project #83313 - Under Construction
Old 12-26-2017, 09:38 AM
Snoho3 Snoho3 is offline
Scott,
Great write up - thanks. I got my IFR ticket in my Cherokee with steam gauges but am really looking forward to completing my -9A which will have the latest from Dynon. The transition will be interesting! Would love to go for a motivational ride with you sometime.
Lars
Snoho3
RV-9A - Flying as of 12-20-2020
2021 Dues+ Paid and worth it.
Old 12-26-2017, 10:07 AM
rolivi's Avatar
rolivi rolivi is offline
Congrats...
I asked the DPE that I did my PPL with if he does IFR checks in Experimentals.
He said, "Depends on the Experimental."
I showed him mine and he said "She'll do."
I considered that a compliment.
Rob
RV-6A (Purchased)
2021 Dues Paid, of course
Old 12-26-2017, 04:46 PM
Yes, I think most will agree, the instrument written is more difficult than the private. But, I always felt it was somewhat relevant to instrument flying, at least more so than the private written was to private flying. Can you give me a few examples of what you think is useless? I?m just curious.
Old 12-26-2017, 09:16 PM
RV7ator RV7ator is offline
Scott,
How much were you allowed to use the autopilot during the ride?
Couple of CFIIs I use as safety pilots on proficiency flights expect me to demonstrate competency with the autopilot besides hand flying.
John Siebold
Old 12-26-2017, 09:37 PM
DakotaHawk's Avatar
John,
The question of "how much autopilot to use during the checkride?" was something that I discussed with all three of my CFIIs.
The first guy, who is very "old school", said that I may be asked to demonstrate it, but not to expect to get to use it for anything other than a basic demonstration during the checkride. The second guy, who is also "old school" said that I could expect to use it when things got real busy in the cockpit, for example to keep wings level while copying clearances. The third guy said to go ahead and use it in all phases of flight, and explain to the DPE when and why I'm using it. I went with the third guy's suggestions.
I used the autopilot during about 80% of cruise/level flight, but turned it off occasionally just to show I could keep the plane level wings/level altitude without the autopilot. I also used the autopilot as ATC was giving me radar vectors to the approach. I made sure to disengage the autopilot before crossing the FAF, although I did re-engage it after the FAF on two of the approaches.
Finally, on the final approach to KRNT, which was a RNAV/GPS approach, the DPE failed my primary EFIS. When he did that, I engaged the autopilot and let it fly the approach while I reconfigured the secondary/passenger EFIS to show the approach plate. All told, I probably used the autopilot for about 50% of my checkride.
Arlington, WA
Old 12-26-2017, 10:47 PM
The current ACS (nee PTS) requires that one of the 3 required approaches be flown with the use of the autopilot (if equipped). It is silent as to enroute use.
Old 12-26-2017, 10:56 PM
e.
What was the point of the disengagement/re-engagement?
I am surprised the examiner allowed you so much autopilot use.
