Go Back   VAF Forums > Model Specific > RV-14
Old 12-10-2017, 08:39 PM
Jake14 Jake14 is offline
Default air creaner bracket keeps getting bent
puzzled why the inboard lip of the air cleaner retaining frame keeps getting bent upwards. When I straighten it, after the next flight, it's bent upwards again about 3/16 to 1/4 in at the fwd inboard corner. It happens whether the rubber seal is short or long. Could the airflow over the bracket create a low pressure region which causes this?
RV-14A flying 520 hrs
Old 12-10-2017, 08:43 PM
Bavafa Bavafa is offline
Is it possible that you have a backfire thru your intake?
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - SOLD
N258SM RV14A - IO390EXP119 - in progress
Dues paid
Old 12-10-2017, 08:51 PM
Question
Haven't heard any backfiring, and the portion of the lip being bent is away from the filter element with nothing below it but the engine cavity.......
Old 12-10-2017, 08:53 PM
Question
the crease of the bend is at the forward edge of the forward retaining screw
Old 12-10-2017, 08:58 PM
crabandy crabandy is offline
I have serious doubts about air pressure being able to bend that metal lip. What's the closest thing the air filter retaining frame can hit? What's the clearance between the air filter retaining frame and the front inlet of the cowling? The lower baffling rubber looks likes it's had some serious rubbing going on, I'm guessing there needs to be more clearance between the cowling and the metal baffling/air filter retainer.
I would trim the cowling inlet another 1/4 inch then redo the rubber baffling material to lay on top of the metal air filter retaining frame.
RV 7 500 hours and counting
20 donation done
Old 12-11-2017, 11:57 AM
KeithB's Avatar
KeithB KeithB is offline
I did not have bending, but I did have wearing of the inlet ramp (metal) on the passenger side inlet. There was a gap at rest of about 1/8", but I believe that during the "dog shake" of engine start and shutdown, the baffle metal was impacting the fiberglass cowl - there is an amazing amount of flexing of that engine on its mount. I trimmed back the metal (or alternately you could trim the fiberglass) and the problem has been solved.
Keith Brown
RV-14A Builder - kit #136 (complete) and #770 (in process)
N314KC - First flight Mar 8, 2017, 24th in the air, >750 hrs
XP-400 Aero Sport Power, replaced with Lyc Thunderbolt 390
RV-6A sold
Sport Pilot (weight-shift control) - Airborne XT912
Dues paid 9/2021
