Old 12-10-2017, 04:45 PM
chrispratt's Avatar
chrispratt chrispratt is offline
Super Moderator
Default FOULED PLUG and IT PAYS TO LOOK AROUND ANTIME THE COWLING IS OFF
If you’ve never seen a fouled spark plug, this is an example of what one looks like. Note on the right side of the photo the bridged gap between anode and cathode effectively shorting out the plug. On mag check during run-up there was a drop of about 300 rpm followed by a backfire. This is an REM38E used on a standard magneto system and carbureted O-360-A1A. You can also see some carbon buildup on the plug walls in the background. I guess I need to floss my plugs more often Ya think I need to lean a bit more? Sure ruined my plans for the day.
BTW the plug had about 230 hours on it so it was just about due to be changed anyway along with the other 7 (I change my plugs at 250 hours).
On the positive side, while changing the plug I also discovered one of the connecting wires from my Unison Shower of Sparks was not in original condition (see below). Don’t know how this gap between connector and shielding happened; looks like I must have snagged it at some point and put a strain on the wire. A new Faston connector was soon substituted.
That’s why it pays to look around anytime the cowling is off.
Chris
Chris Pratt (2021 VAF DUES PAID)
RV-8 Flying, 850+hours
N898DK
Lycoming O-360-A1A, Hartzell CS
52F (Northwest Regional, TX)
Old 12-10-2017, 07:32 PM
Walt's Avatar
Walt Walt is offline
Looks to me like some kind of automotive wire was used and the insulation shrunk back. Rip it out and start over
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
RV7A built 2004, 2000+ hrs, New Titan IO-370, Bendix Mags
Old 12-10-2017, 08:20 PM
chrispratt's Avatar
Super Moderator
That may be, Walt. That's the wire that came with the original unit and being a rookie builder at the time (about 14 years ago) I used what the OEM sent. I replaced it with Tefzel wire.
N898DK
Old 12-11-2017, 06:00 AM
fixnflyguy fixnflyguy is offline
Default Happened to me too..
Same thing just happened to me last week, but I had a cracked insulator that made it even worse. I was accused of "making Popcorn" during run-up the popping was so loud! Same exact plug type.
Bill E.
RV-4/N76WE
8A7 / Advance NC
Old 12-11-2017, 06:31 AM
scard's Avatar
scard scard is offline
I love my fine-wires!
Scott Card
CMW E-Lift
VAF Advertiser
Old 12-11-2017, 07:10 AM
6 Gun 6 Gun is offline
Smile Plugs
I have ran NGK auto plugs for last 100 hours on one of my slick mags gapped at out of the box .025 has worked very well and cost $2.30 each don't know how to post pics but if anyone wants to know how I converted wire to auto send me a PM.
Old 12-11-2017, 08:20 AM
az_gila's Avatar
az_gila az_gila is offline
Exclamation
That sort of fouling is good reason to change to the REM37BY plugs with extended tips -
Should be good and approved in all of our engines, but you can check here -
https://www.lycoming.com/sites/defau...rk%20Plugs.pdf
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 12-11-2017, 08:30 AM
blastinbill blastinbill is offline
Default Fouled Plugs
I have had trouble with lead-fouled REM-38E massive plugs in both the previous Lycoming O-360A1A in my Piper Comanche and in the present engine until I switched to 4 Tempest fine wires on the bottom and REM-37BY's on the top about two years ago. No problem since, and I can go lean of peak until misfire occurs a lot farther than before.
Old 12-11-2017, 08:36 AM
Bob Martin's Avatar
Bob Martin Bob Martin is offline
Default Mags
I was under the impression the Sparkplug gap was determined by the source of the ignition and the mags were designed for 18 to 20..?
A bigger gap is taxing the coils/etc and will eventually lead to failure.
Food for thought.
Bob Martin
RV-6, 0-360 Hartzell C/S, Tip up, 1200+TT
James extended cowl/plenum, induction, -8VS and Rudder. TSFlightline hoses. Oregon Aero leather seats.
D100-KMD150-660-TT ADI2- AS air/oil seperator. Vetterman exhaust with turndown tips.
Louisa, Virginia KLKU N94TB
Old 12-11-2017, 09:21 AM
DNeufeld DNeufeld is offline
Food for thought.
Yep, me too.
The higher the secondary voltage, coil, plugs and plug wires, the higher the primary voltage, points, condenser, coil. High voltage is always looking for an easier path to ground. Also burns points...
