Old 11-29-2017, 08:09 PM
Michaelpk3 Michaelpk3 is offline
Default HDX panel upgrade
Recently had Saint Aviation replace a 6 pack with 10" HDX, install new G5, XM radio and upgraded 430W to 650. He did an outstanding job. The combination is a great IFR/VFR platform. It works well with Vision 385 AP. They guys did an excellent job with the wiring and the install. Truely a profession install. I would highly recommend both the product and Saint Aviation to anyone thinking of an upgrade.
https://photos.app.goo.gl/1v9OCDmNfytNUqSM2
https://photos.app.goo.gl/2Gw10ID7EsfGhMjx1
https://photos.app.goo.gl/0MTXGxZUvdZS57LI3
Michael Kalfsbeck
Michaelpk3@yahoo.com
N505AT RV-7A based in Sarasota, FL
Old 11-30-2017, 02:25 PM
RONSIM's Avatar
RONSIM RONSIM is offline
Default Mike -- turned out really nice!
Anxious to fly with you to see how it works.!
Ron
RV-10 Co-built, maintained, flown (sold)
RV-8A Maintained and flown (Sold)
RV-6A (Sold) Bought and Flying (N177RV), upgrades $$$
IO360, 180HP/CS, AFS 5600T, D10A, G650, G430, G327, ADS-B, VIZ385 AP
Very Happy Contributor
Comm, SMEL, CFII, A&P
Based at KCLW (Clearwater, FL)
Old 11-30-2017, 05:48 PM
MercFE MercFE is offline
Curious why you kept the Vision AP instead of going with the integrated... Not wanting to swap out servos?
Old 12-01-2017, 09:19 AM
Dugaru's Avatar
Dugaru Dugaru is offline
Default Well done
Really, really nice setup there.
N929JA, 2007 RV-9A
Based W96: New Kent International Aerodrome
(near Richmond, VA USA)
2021 Dues Paid
Old 12-01-2017, 12:09 PM
I kept 385 for a couple reasons... not wanting to change servos, and back up if the screen (and battery back up) fail. I will change out in the future. I can switch AP over to Skyview to do GPS NAV mode from the Skyview flight plan and track mode from HDG bug on the panel.
Michael Kalfsbeck
Old 12-01-2017, 12:39 PM
gasman gasman is offline
Michael, I noticed your canopy struts are mounted up side down. Mounted with the shaft down, the seal gets better lubrication. Also, the strut has a built in buffer that will keep the canopy from banging at the top of the extension. This will only work if it is properly installed.
VAF #897 Warren Moretti
2020 =VAF= Dues PAID
