Old 11-28-2017, 08:58 PM
simatos simatos is offline
Unhappy bonehead move --Garmin Pitot Tube
trying to do a pitot leak test on the Garmin pitot tube. System had leak but all tubes checked out. Bite the bullet and disconnected pitot and yank out. The pitot has 2 tubes set up one ahead of the other, problem is I didn't mark which is pitot and which is Angle of Attack. Anyone out there know which is which???????
I don't want to sign this because I'm too embarrassed
Old 11-28-2017, 09:04 PM
9GT's Avatar
9GT 9GT is offline
If no one helps you out tonight, I have a new one in my hanger and can get that info for you tomorrow.
David C.
Howell, MI
"Donor Exempt" but donated through Dec. 2021
Old 11-28-2017, 09:10 PM
Mel's Avatar
Mel Mel is offline
If the pitot is off the airplane, blow into the hole that points forward. That one is the pitot. The AOA inlet hole will be on the bottom angling about 60° down from horizontal.
Mel Asberry, DAR since the last century. Over 1,000 certifications accomplished. Discount for Veterans, Law Enforcement, Fire Fighters.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 11-28-2017, 09:11 PM
mill2978's Avatar
mill2978 mill2978 is offline
The g3x install manual shows the Pitot on the fwd and the AOA on the aft. Page 5-7 in my version.
Aaron Miller
RV8 N127KT - First Flight October 16, 2018
http://www.mykitlog.com/AaronMiller/
Old 11-28-2017, 09:45 PM
Originally Posted by Mel View Post
If the pitot is off the airplane, blow into the hole that points forward. That one is the pitot. The AOA inlet hole will be on the bottom angling about 60? down from horizontal.
The KISS principle at its best!
Old 11-28-2017, 10:43 PM
Thanks Guys
you have saved my bacon once again,
Cheers G
