Old 11-19-2017, 05:13 PM
JDA_BTR JDA_BTR is offline
Default Silicone under canopy screws
On the rear window the plans call for a dab of silicone under the screw heads. Is this not done for the main canopy? It isn?t mentioned.
Ser 140142, RV-14A flying - N1463
Ser 83825, RV-8 building - N8638?
USN Ret, Urologist, AME, Repeat Offender
Old 11-20-2017, 09:23 AM
rvbuilder2002's Avatar
Roll bar screws only.
The purpose is not to seal the screw head, but to retain the screw so it doesn't back out of the plain threads tapped in the roll bar.
That is why it is called for in the hole / on the threads, not under the screw head.
Scott McDaniels
Hubbard, Oregon
FAA/DAR
Old 11-20-2017, 02:33 PM
jeffw@sc47's Avatar
jeffw@sc47 jeffw@sc47 is offline
I will add > If you think that a dab of a thread lock solution would be a better thread lock than the silicone - DON'T DO IT.
The reason that you use silicone as a thread lock is that any kind of a "LOCK-TITE" thread lock will do bad things to the plexiglas material.
I havn't had to learn this the hard way, but someone I know did and I've seen more than one post that warns against using any kind of lock-tite anywhere near plexiglas.
Just a reminder.
Jeff Warren
Simpsonville, SC (@SC47 > 10nm NW Triple Tree)
RV14A (N14ZT), Ser#140195
Start 10/11/14; AWC Rcvd 7/21/21
Contribution made 12/2/20 (USArmy 2/67-2/70)
www.mykitlog.com/jeffw@sc47
Old 11-20-2017, 02:42 PM
Bavafa Bavafa is offline
Just a reminder.
A friend of mine did this and it caused his canopy to crack, don't know how but his cracked even before flying.
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - SOLD
N258SM RV14A - IO390EXP119 - in progress
Dues paid
Old 11-20-2017, 04:08 PM
Steve Melton's Avatar
I use VC-3 on canopy screws. it is safe for plastic.
https://www.amazon.com/Vibra-TITE-21...&keywords=vc-3
Steve Melton
Cincinnati, OH
RV-9A, Tip-up, Superior O-320, roller lifters, 160HP, WW 200RV, dual impulse slick mags, oil pressure = 65 psi, EGT = 1300F, flight hours = 900+ for all
I was born an airplane nut. I have no explanation for it.
www.rvplasticparts.com
Old 11-20-2017, 06:42 PM
Understood all around.... good info
Old 03-01-2019, 08:43 PM
mturnerb mturnerb is online now
Resurrecting this thread as I'm about to install this window.
Dumb question: What kind of silicone?
Turner Billingsley
RV-14A built/sold N14VB
RV-12iS in progress as of October 2020
