Old 11-15-2017, 10:57 AM
JackinMichigan's Avatar
JackinMichigan JackinMichigan is offline
Default Air to ground frequency
I took my RV-10 up on its first flight this past Saturday, and I was talking to my father on the ground with a handheld tuned to 123.45. Mostly I was keeping him informed as to what I was doing and how the plane was behaving, but 10 minutes in someone broke in with a curt 'Get off this frequency!'
It's my understanding that 123.45 (known as 'fingers' apparently) is reserved for air-to-air and civilian flight testing, so I'm not sure who I was intruding on or if that person had any business telling me what he did.
What's the proper frequency I should be using to communicate with my ground crew while flight testing?
Jack and Dave Groat, father and son
RV-10 N1861G
Build #41389, started Oct 2012
Current status: 1st Flight 11/10/17
50 hour oil change: 8/29/19
Old 11-15-2017, 11:20 AM
Mark Dickens's Avatar
Mark Dickens Mark Dickens is offline
He was the jack@ss. 123.45 is used for flight test, along with several other frequencies. He was the one who was breaking the law.
RV-8 #81077 Super Slow Build
Dynon Skyview HDX, Titan IOX-370, Dual P-Mags, AFP FM200A FI, Whirlwind 200RV CS Prop
First Flight 11/20/2016
https://www.marksrv8.com
Old 11-15-2017, 12:36 PM
flyinga flyinga is offline
From another forum:
Inside the contiguous 48 United States, 123.45 is NOT a valid air-to-air frequency. It is assigned to flight test for various airplane manufacturers by the FCC.
Ref: 47 C.F.R. ? 87.303(a) for 123.45 MHz
Jim Averett
RV-8
TS36 - Silver Wings
Fredericksburg, TX
Old 11-15-2017, 12:46 PM
keen9a's Avatar
keen9a keen9a is offline
Just to clarify, before you use 123.45 you need to have it assigned to you. You may have been stepping on someone's flight test communication.
Ben Keen
RV-9 Flying 8/21/2016
http://www.pbase.com/benkeen/rv9
Old 11-15-2017, 01:18 PM
Raymo's Avatar
Raymo Raymo is offline
Fixed wing aircraft air-to-air is 122.750
https://www.radioreference.com/apps/db/?aid=7758
Ray
RV-7A - Slider - N495KL - First flt 27 Jan 17
O-360-A4M w/ AFP FM-150 FI, Dual PMags, Vetterman Trombone Exh, SkyTech starter, BandC Alt (PP failed after 226 hrs)
Catto 3 blade NLE, FlightLines Interior, James cowl, plenum & intake, Anti-Splat -14 seat mod and nose gear support
All lines by TSFlightLines (aka Hoser)
Old 11-15-2017, 01:27 PM
I had never heard that. I had always heard that it was for use by aircraft manufacturers for test purposes, but I'd never heard it had to be assigned to you. Where is that stated in the law or rules? Always looking to learn!
Old 11-15-2017, 01:41 PM
Bevan Bevan is offline
For the Canadians monitoring this thread: In Canada, 123.45 Mhz is an air to air frequency for use in Canadian Northern Domestic airspace and the North Atlantic.
Bevan
RV7A Flying since 2015
O-360-A1F6 (parallel valve) 180HP
Dual P-mags
Precision F.I. with AP purge valve
Vinyl Wrapped Exterior
Grand Rapids EFIS
Located in western Canada
Old 11-15-2017, 02:21 PM
Ironflight's Avatar
VAF Moderator / Line Boy
https://www.faa.gov/documentLibrary/...%20Chg%201.pdf
Scroll down to about the fourth page, paragraph 908: SPECIAL USE OF 123.45. It's used for Fight test - but NOT for Air to Air. I know a couple of avionics engineers who have told me that they (their company) had the frequency assigned for a particular test, in a particular area, and then had guys romping along using it indiscriminately ruin their test.
Frequency allocation is one area where everything is prohibited unless expressly permitted......
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 11-15-2017, 02:24 PM
And I was just informed by a more informed friend that the FAA flight test folks use it to talk to ATC as well.
Old 11-15-2017, 02:55 PM
So back to my original question - what frequency SHOULD I be using? If I need one assigned to me who does that, the FAA or the FCC? Who do I contact?
RV-10 N1861G
