Old 11-02-2017, 07:16 PM
Weasel's Avatar
Weasel Weasel is offline
Default Playing with the 3D printer...again
needed a bracket for carb heat on the Cub
Thang is perdy handy now an again
decided to go ahead and work up some heater floor diffusers while I was in the mood.
Weasel
RV-4 715hr Sold
RV-10 "School Bus" - +1700hr counting
RV-10 N7631T 820hr Sold
RV-8 700+hr
SERFI AWARDS
http://weaselrv10.blogspot.com/
Old 11-02-2017, 08:11 PM
BigD BigD is offline
Good idea. Now design a door hinge pocket cover, and I'll be all over it...and a keychain tool for popping open the gas caps...
==dave==
N102FM
Old 11-09-2017, 10:06 AM
Weasel's Avatar
Default few more pieces
The only available heat currently for the cabin is one 2" heating air duct through the firewall. The idea is to distribute more of the hot air to the rear seat than the front. The front guy always seems hot and rear cold.
The slot facing the floor is to heat front seat with the 2 small ducts splitting to feed warm air to rear seat.
2" duct feeding all this will likely not be enough....
Weasel
RV-4 715hr Sold
RV-8 700+hr
SERFI AWARDS
Old 11-09-2017, 09:22 PM
BenNabors BenNabors is offline
Default Thermal plastic and heat
What is the maximum air temperature verse the plastic deformation temperature of the thermal plastic?
Old 11-10-2017, 03:23 PM
BMC_Dave BMC_Dave is offline
There are also significant flammability, smoke, and toxicity issues to be aware of when using ABS. Something to keep in mind when using around the firewall or heat box.
Old 11-10-2017, 03:31 PM
flyboy1963's Avatar
Default $$$$$$$$$??????????
this stuff is awesome, and inspirational for us guys hoping to retire some day. ( fantasizing now about a hangar with scads of tools & gadgets like this....)
........so, how much, really, in airplane dollars, if a guy wanted one of these parts?
If I go out and get a printer, I know a little CAD etc....but will it cost $100 for resin ( and a few spoiled pieces) for a useable $5 duct?
just askin'!
Perry Y.
RV-9a - SOLD!....
Lake Country, BC
Old 11-10-2017, 03:43 PM
DaleB's Avatar
DaleB DaleB is offline
Oh, no - not at all. Check out the prices of kilo spools of ABS, PLA and even nylon on Amazon. "1.75mm filament" is what you want to search for.
Dale
Omaha, NE
Previous RV-7 project (sold)
Old 11-10-2017, 03:53 PM
Oh yeah, 3D printing is quite cheap nowadays. And will be getting even cheaper.
Just use it for things that won't matter if they break...
Old 11-10-2017, 03:55 PM
sblack sblack is offline
oh, so I shouldn't be 3d printing that spar I was working on? Dang!
Scott Black
VAF dues 2020
Instagram @sblack2154
Old 11-10-2017, 04:13 PM
DaleB's Avatar
Oh, you probably can... it would just cost several orders of magnitude more.
https://3dprinting.com/metal/boeing-...ium-parts-787/
Dale
Omaha, NE
