Old 10-25-2017, 03:37 PM
Pukauma Pukauma is offline
Default Another overhead canopy
I finished my overhead console a couple of months ago. Have received a lot of help from others, and was pleased with my finished product. Thanks for all the help and advice along the way.
Access panels and switch plate are veneered with amboyna burl (off of ebay). I intend on doing the same to panel inserts. Had a disaster first run with spray adhesive, was finally successful bonding veneer with G-flex epoxy. And found that my wife's food sealer is great for vacuum veneering. Finish is a 2k clear, spraymax.
Paint is Sherwin-Williams JetFlex Solvent-Based Polyurethane Enamel
L09027 - Blue Black, satin. Over epoxy resin and micro, some fiberglass to cover the 3/4" flex conduit in the anterior groove adjacent to the windscreen. I extended the Aerosports console to hide the conduit.
Various LED bolt lights, map lights, and mostly rocker switches that have LED indicators on them. A few bump outs to help position things.
Lots and lots of sanding and filling, but in the end I enjoyed it and the final result.
Cliff Langlois
Meridian, Idaho
Cliffsrv10.blogspot.com
Project Sold 9/2018
RV-10
Empennage finished!
QB Fuselage and wings in hand
Taking a bite of the elephant every day.
Old 10-25-2017, 04:02 PM
DanH's Avatar
DanH DanH is online now
I always enjoy seeing work that pretty.
Dan Horton
RV-8 SS
Barrett IO-390
Old 10-25-2017, 05:44 PM
rvdave rvdave is offline
I like what you did in the front of the overhead making a cover for the brace nuts, I wish now I would?ve done that to mine .
Dave Ford
Cadillac, Mi
Old 10-25-2017, 05:56 PM
madhun madhun is offline
That?s a really nice job!
Quentin Carter
Bushby Mustang II - 170hrs and counting
$500, if Mrs. Hun ever asks aircraft parts are $500!
Old 10-25-2017, 06:04 PM
Lynnb's Avatar
Lynnb Lynnb is offline
That looks great!
RV-10
First Flight 12-17-2020
Old 10-25-2017, 08:46 PM
XPPilot XPPilot is offline
Looks great!
What is the name for the Map Lights you used?
Old 10-25-2017, 11:32 PM
Default Map lights...
Aircraft Spruce, 754 Series LED cockpit light.
http://www.aircraftspruce.com/pages/...kpitlights.php
Thanks for all the nice comments.
Cliff Langlois
Meridian, Idaho
Project Sold 9/2018
RV-10
Empennage finished!
Old 10-26-2017, 07:31 AM
jcarne's Avatar
jcarne jcarne is offline
As a woodworking teacher I can appreciate that big time! Amboyna burl is a beautiful wood, great choice!
Jereme Carne
PPL
RV-7A Flying as of 03/2021
Exempt but gladly paying!
Old 10-26-2017, 11:23 AM
az_gila's Avatar
az_gila az_gila is offline
Question Q
Looks great, and I'll copy some of it... - but one question about the paint.
Why did you choose the solvent based JetFlex over the water-based version?
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 10-26-2017, 08:32 PM
Default Paint.....
I purchased my paint through Alliance Coatings, they were very helpful for a novice painter. They referred me to a SW rep for technical (spraying) questions.
The tech sounded like a professional painter who was very knowledgeable. He advised me that as a novice painter I would do better with solvent based. He also felt that cleanup with the water base was more difficult and messy. I have no experience, so I took his word on all we discussed.
He also advised me to reduce the paint on the upper end of the recommended range. I followed his advice, and had a great experience with this product. I have a butt load left over, but still have things to paint. Better than running out.
Cliff Langlois
Meridian, Idaho
Project Sold 9/2018
RV-10
Empennage finished!
