Old 09-24-2017, 08:37 PM
Bradp Bradp is offline
Default How to minimize ground loops
Hi all-
I had a quick question about ground loops. I am going to be wiring a PMA 8000 series audio panel to an old KX-170B Nav/Com. The KX-170 used unshielded wiring and lacks pinouts for "audio low". I wanted to know which would be the proper method to wire the com output to a modern audio panel.
https://photos.app.goo.gl/m156OWCR4wGQzAVr2
The first option would have the audio low outputs for nav and com brought together to the current airframe ground at back of the KX-170B. The shield terminations would be grounded at the audio panel back shell with everything else.
The second option would have the low audio outputs for nav and com brought back to ground with the shield terminations at the back of the audio panel (all grounds shared at the back of the audio panel).
Seems like the second option would be the preferred method for minimizing ground loops, but I wanted to check with the group. I can't seem to find much in the way of printed guidance on these old - new interconnects.
Thanks and take care,
Brad
Old 09-24-2017, 08:49 PM
DennisRhodes DennisRhodes is offline
Keep the upwind wing low up to and in the touchdown and don t let it get that cross wind lift under it at least for a non A model
DRRhodes
2021 VAF Supporter
RV9 N908DR
Old 09-24-2017, 09:10 PM
Option 1. This will minimize ground loops. The audio low input is isolated from true ground.
Old 09-25-2017, 12:23 AM
donaziza's Avatar
donaziza donaziza is offline
Heck---And I thought this thread was going to be about "How to minimize ground looping"
Old 09-25-2017, 07:50 PM
vlittle's Avatar
vlittle vlittle is offline
Originally Posted by Bradp View Post
Hi all-
Brad
Ideally, option 1 with the shield grounded at either end (to the audio ground) would be the best. Your noise source will be the difference in ground potential between the comm and the audio panel, so they should each be connected to the same power ground.
By connecting both audio high and audio low this way, noise caused by the ground differences should be rejected by the audio panel. I don't have the audio panel schematic handy, but I it should have a fully differential input structure for this purpose.
Of course, once the engine is running, the noise won't matter....
V e r n. ====
RV-9A complete
Harmon Rocket complete
Part of EAA award-winning OnSpeed team
The VV in huVVer.tech
Victoria, BC (Summer)
Chandler, Az (Winter)
